Best boost/overdrive with jcm800 2203
Discussion in 'The Tone Zone' started by On_the_edge_of_time, Sep 22, 2020.
  1. On_the_edge_of_time
    On_the_edge_of_time New Member
    Sep 17, 2020
    4
    2
    Looking for something as an always on pedal to boost the gain a little and tighten the bass up for palm muting. Going for an early Metallica type tone, a little thicker/heavier maybe. I’ve been going back and forth between a ts808 and a walrus iron horse(like a rat with more bottom end), both sound cool but cut the bass/thin things out and color the tone a little too much
  2. lespaul339
    lespaul339 Well-Known Member
    Dec 28, 2010
    757
    891
    Iowa
    I always thought a SD1 is one of the best sounding pedals to go with a 2203. When I use to have my 2203, that's what I used and I played thrash metal back then very much in the vein of Metallica and Iron Maiden and that pedal was perfect!
    tidbit, Drinkingdeath01 and Neptical like this.
  3. mustafa
    mustafa Member
    Apr 29, 2013
    28
    51
    Try tube screamer mini with the tone and gain turned completely down, volume maxed.
    Ufoscorpion likes this.
  4. Filipe Soares
    Mar 8, 2019
    1,538
    2,675
    I have several OD/boosts at home and my go to pedal to use with my 2203KK is the SD1
    lespaul339 likes this.
  5. K2JLX
    K2JLX Well-Known Member Gold Supporting Member
    Apr 20, 2018
    368
    736
    New York
    Everyone says SD1. I’m going to say a clean boost Bogner LaGrange.
  6. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    1,553
    2,132
    Back in the 80’s I used a ts9 with my 2204 then switched to an sd-1 . Always thought it sounded more aggressive than the ts9 but pretty generic compared to what we have now.
  7. Filipe Soares
    Mar 8, 2019
    1,538
    2,675
    my go to pedal for other amps is a clean boost, like the mooer pure boost, but the SD1 sounds better with the 2203kk
    tce63 likes this.
  8. Matthews Guitars
    2,667
    3,914
    My clean boost pedal (and literally the only pedal I own) is a Seymour Duncan Pickup Booster. The sweet spot is around the 10 dB boost setting. Above that, things get noisy and overstuffed.
  9. DaDoc
    DaDoc Well-Known Member
    Oct 13, 2014
    3,424
    4,021
    Rancho Deluxe, 3rd stone from the sun
    One of the hands-down best pedals I have ever found is the B.K. Butler Tube Driver. It's a bit pricey but you can get pretty much any kind of distortion/overdrive ya want, and it's got a very natural-sounding tone. It uses a 12AX7 and is AC only, so you have to be able to plug it in.
  10. pedecamp
    15,356
    13,046
    Rat, TS9, SD1, GE7, not in any particular order, use each one depending on the tone at that moment. :yesway:
    Ufoscorpion and Sustainium like this.
  11. Neptical
    Neptical Well-Known Member
    Jun 13, 2010
    173
    277
    NH
    1.) BOSS SD-1 ( don't use mine much anymore but that pedal is BEAST mode with the JCMs)
    Currently Using:
    2.) MXR 10 Band M108s - Volume and Gain is crazy handy and the sculpting possibilities are endless. Very powerful pedal to own.
    wntbtw and lespaul339 like this.
  12. tallcoolone
    tallcoolone Well-Known Member
    Mar 7, 2011
    1,088
    1,751
    I could make an argument for about 2 dozen pedals I have in my closet for this application lol. TS, Klon/klone, sd1, Timmy, ep preamp and Rat are pretty much the broad variations besides the aforementioned trusty ole eq!
    I like Klones lately, although it seems as though the ones I like the most are the noisiest lol. But we all know why that is—the more we likey, the louder and more gain we want!
    WellBurnTheSky and HOT TUBES 70 like this.
  13. jjrockthatguitar
    jjrockthatguitar New Member
    Apr 1, 2020
    16
    The majik box Doug Aldridge Rocket Fuel is by far the best boost pedal for my 800 and plexi’s I’ve ever come across.
    It has a clean boost and an overdrive in the one pedal, they can be used separately or together. Awesome pedal, check it out
  14. HOT TUBES 70
    Oct 13, 2008
    11,236
    5,741
    Klon circuits are fantastic , after all Bill Finnegan from Klon specifically designed that circuit to out perform the Tube screamer in this situation . The Klon keeps your core original tone intact far better than a TS , or any variant imo . Its a very unique pairing the two make , a cranked up Marshall and a Klone .
    wntbtw likes this.
  15. Iron1
    Iron1 Well-Known Member
    Aug 14, 2020
    128
    286
    South Texas
    SD-1 all day, every day. Tried a bunch of others, always come back to the SD-1.
    FogDweller and lespaul339 like this.
  16. Nmoc strat
    Nmoc strat Active Member
    Jan 2, 2015
    219
    162
    SD-1
    That pedal was made with the JCM800 in Mind, even the colour matches.
  17. AlboK
    AlboK Member
    Sep 24, 2019
    51
    33
    YEP. SD-1 sounds best, I've tried many other pedals. Yet my SD-1 sounds terrible with my Silver Jubilee but amazing with my 2204 & JCM 2000 DSL 50.
    Iron1 and lespaul339 like this.
  18. AlboK
    AlboK Member
    Sep 24, 2019
    51
    33
    NO way, I have both and the SD-1 kills that Tube Screamer.
  19. Reauchambeau
    Reauchambeau New Member
    Jan 23, 2013
    8
    12
    Vancouver B.C.
    I still have my 1983 CSA 2203, I was 16 when the JCM800’s emerged. Back then it was DS-1, TS-9, or SD-1, wasn’t a lot to choose from really. We quickly figured out that the SD-1 and the 2204/2203 was a match made in Heaven. The DS-1 was too much and the TS-9 was too mid pushed. So yeah SD-1 all day everyday.
    lespaul339 and wntbtw like this.
  20. FleshOnGear
    FleshOnGear Member
    May 2, 2017
    85
    97
    +1 SD-1
    If you are looking for something else, I’ve had great success with the Nobels Natural Overdrive into the crunch mode of the green channel of my DSL. Never tried it into a JCM800, though.
