Best attenuator
Discussion in 'Let's Talk Vintage' started by pman, May 27, 2010.
  1. pman
    pman New Member
    Sep 15, 2006
    55
    Fauxnix
    I need to get an attenuator for my 69' BB. I took a 5 year LOA from using them. I had a Marshall PB-100 that was very marginal tone-wise. I decided to stop using it when, after a gig, it became a "real brake" when I partially ran over it. I have heard great things about the Hotplate. Any thoughts on which is the safest and gives a truer tone.
  2. Hamohapic
    Hamohapic Member
    Apr 8, 2010
    153
    9
    hey pman, from what i have read, Weber attenuators are suppose to be nice, and the don't suck as much tone.
  3. wkcchampion
    wkcchampion New Member
    Oct 19, 2009
    2,242
    22
    Italy
    Yep, they don't at all. I did a recording test in 2007 (against a Hotplate and a Powerbrake) and the Weber was the only one to keep the tone virtually identical up to speech volume.
    Unofrtunately, the files got lost in a hard disk crash the next year...
    In general, I think that boutique, hand-made attenuators like Weber are the best.
  4. pman
    pman New Member
    Sep 15, 2006
    55
    Fauxnix
    That's what I have been hearing. On another note, today's EL34's have lower tolerance ranges compared to the NOS Mullards, Sieman's and Dynaco's. The vibration from this amp has killed 3 sets of PT's. It's plate voltage is at 475 and runs 60Watts clean. I was told that installing rubber O' rings on the tube sockets may help, taking off the back baffle or maybe switching to a different tube may help. Any thoughts?
  5. Hamohapic
    Hamohapic Member
    Apr 8, 2010
    153
    9
    Yah, i am looking into geting one, and Weber is on top of my list right now.
  6. solarburnDSL50
    Aug 8, 2008
    17,186
    13,026
    Wetville
  7. wkcchampion
    Oct 19, 2009
    2,242
    22
    Italy
    Does that device have Line-out options? I didn't see any on the website. Am I blind?
  8. solarburnDSL50
    Aug 8, 2008
    17,186
    13,026
    Wetville
    I'm not sure Marco. I'll see what I can find out...
  9. solarburnDSL50
    Aug 8, 2008
    17,186
    13,026
    Wetville
  10. solarburnDSL50
    Aug 8, 2008
    17,186
    13,026
    Wetville
    Here you go Marco:
    Product Highlights:
    * Proprietary SRT Power Attenuation Technology
    * Six levels of step attenuation, plus a continuously variable attenuation control (bedroom mode)
    * 150 watt power rating
    * Independent input and output impedance selector switches:
    - from the amplifier and into the attenuator, select from: 2, 4, 8, 16 ohm
    - from the attenuator and to the speaker cabinet(s), select from: 2, 4, 8, 16 ohm
    Uniquely allows 16 possible Input and Output impedance combinations
    * Features a Load setting and is equipped with a Line Out Jack and Line Out Level Control
    * Rack Mount Option
    * Handwired in the USA
  11. wkcchampion
    Oct 19, 2009
    2,242
    22
    Italy
    Yeah, the list wasl ong and I missed it. It's a GREAT piece of gear. I wouldn't buy it for the price thogh, the Webers cost ONE THIRD :wtf:
  12. nikininja
    nikininja New Member
    May 25, 2010
    78
    8
    UK
    Hi,
    I have a powerbrake that I've been using for close on a year now on both a 4211 and a 2203kk. Can I ask what difference in tone you've heard? Reason I ask is that I cant hear any difference I couldnt attribute to speakers not being pushed as hard. I must admit from the one time I tried a weber mass, it was great. The added treble seemed to make up for a lot, but nothing I couldnt get close to with eq adjustment. Not bang on, but close.
    Also what do you tend to run your master volume controls at? Do you get through powervalves much quicker for it?
    Thankyou.
  13. pman
    pman New Member
    Sep 15, 2006
    55
    Fauxnix
    So, as I understand, the Weber Mass Attenuator is the one to get. Has anyone ever heard of Ho's Attenuator. They are supposed to be the the exact same, except on is labeled "ultimate attenuator". Is $225 a good deal for the Weber Mass 150W 4-16 Ohm? What is the Mini Mass?
  14. Lespaulnmarshall
    Lespaulnmarshall Well-Known Member
    Aug 31, 2009
    5,533
    892
    I'd highly reccommend the Weber mass, the hot plate and the Loadbox.
  15. Gryphon
    Gryphon Member
    Dec 27, 2008
    114
    10
    Los Angeles, CA
    I use a Weber Mass Lite and it takes a 50w JCM900 down to home practice levels no problem. The box contains a dummy speaker (no cone) plus rheostat so it does a great job of dumping the power into a reactive load. It has separate Lows-Mids and Mids-Highs controls to adjust the tone balance as you attenuate more and more, which is important
  16. eljeffebrown
    eljeffebrown New Member
    Mar 10, 2010
    4,404
    1,180
    Banding, Snorkeling, High Speed Line Skipping, Boo
    Weber, ANY!
  17. customwhite
    customwhite Well-Known Member
    May 2, 2009
    986
    319
    Helvete
    The Marshall Powerbrake is the only thing
    I've been using. worked well for me.
  18. pman
    pman New Member
    Sep 15, 2006
    55
    Fauxnix
    I am moving some stuff on Ebay and will get one. Thanks for all the input.
  19. wkcchampion
    Oct 19, 2009
    2,242
    22
    Italy
    My tests were about recording the same riff (reamped) with the VOX AC30 CC2X (which was still unmodded at the time) at full throttle with the same identical settings and mic placement (an SM57 on axis), just varying the attenuation level on the various attenuators.
    The Weber kept the tone virtually the same up to speech volume - but at that point the speakers are not driven enough and the mic itself is trying to capture the sound (they're designed to catch LOUD sounds of course).
    The THD started to get brittle and harsh after -10 or -12 dB, the Powerbrake instead got muddy. Also both attenuators tend to lose the "spongy" feel of a cranked amp, they get a bit compressed after that level of attenuation. The speaker motor load of the Weber retains a very good feeling (this was not heard in the clips which, as said, featured a reamped riff, but this was my impression when playing).
  20. pman
    pman New Member
    Sep 15, 2006
    55
    Fauxnix
