"Bedroom" volume - someone please invent this ASAP
Discussion in 'The Backstage' started by Vinsanitizer, Aug 25, 2021.
  1. mickeydg5
    mickeydg5 Well-Known Member
    26,709
    13,887
    united States of America
    Try a speakerless cabinet (aka empty cabinet). They are dead quiet.
  2. mickeydg5
    26,709
    13,887
    Yes, everyone had better watch it!
    Vin may try to slip you his new found Banana!
  3. mickeydg5
    26,709
    13,887
  4. Vinsanitizer
    Vinsanitizer ✴✴✴✴✴✴✴✴✴✴✴ ✴- - - - - TEH - - - - -✴ ✴✴✴✴✴✴✴✴✴✴✴ Double Platinum Supporting Member VIP Member
    Oct 19, 2012
    30,687
    27,706
    Ahhh, yes. FREE banyana boat for yoo!
    Two Three scoop on hot day:
    Mitchell Pearrow and SkyMonkey like this.
  5. AtomicRob
    AtomicRob Active Member
    Feb 4, 2009
    429
    244
    California
    Sound does not travel through a vacuum. You basically need your practice room to be a giant, 10ft wide, vacuum-insulated thermos with you and your 100w Marshall inside. Sort of like this, but bigger.
  6. Vinsanitizer
    Oct 19, 2012
    30,687
    27,706
    "...I want a device of some sort that allows me to crank any amp up to 100 watts as loud as I want and play it at that volume, but I want there to be complete silence so that you can hear a pin drop outside a 10 ft. radius of the amp."
  7. AtomicRob
    Feb 4, 2009
    429
    244
    California
    Sorry, I didn't read your requirements correctly. I'm an engineer and this is an embarassing mistake. If you want complete silence outside of a 10ft. RADIUS, then duh of course it would have to be a 20ft wide thermos, not 10ft.
    (Edit. Assuming of course that by width of the cylinder I am referring to the diameter.)
  8. Vinsanitizer
    Oct 19, 2012
    30,687
    27,706
    Later in the thread I further specified that I wanted the device to be about the size of a sandwich and cost under $300 retail, and also that it has to be portable, meaning, it has to at least be able to fit in the back seat of your average autobomile.
  9. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,875
    3,798
    With tubes!
    If you loosened your specification a bit to where the device could fold down / minimize itself for portability you might be one angstrom closer to your goal or is it too early to call in Harry Potter? Yep, I went there...
    I'd thought about iso cabs a bit with a second box that was filled with vacuum [sounds odd] and a maglev gizmo to decouple the inner box from the floor. Of course big enough for a 4x12. It never got off the planning page.
    Now back to your regularly scheduled or withheld bananas.
    Russ
  10. Vinsanitizer
    Oct 19, 2012
    30,687
    27,706
    Ok. Yeah, I can do that. Foldable/ compactable would work.
  11. Vinsanitizer
    Oct 19, 2012
    30,687
    27,706
    (This space reserved.)
  12. dro
    dro Well-Known Member
    Aug 1, 2015
    1,235
    2,153
    Blue Springs Mo
    No Thanks. I've got my own banana. :monkey:
    Vinsanitizer likes this.
  13. mickeydg5
    26,709
    13,887
    No thanks.
    It will probably arrive like this.................
  14. Vinsanitizer
    Oct 19, 2012
    30,687
    27,706
    You people are a bunch of preverts.
    I mean REAL bananas. You know, like this:
  15. mickeydg5
    26,709
    13,887
    Right. :cool:
  16. SkyMonkey
    3,610
    5,024
    Cool. I missed the boat on Bitcoin.
    Won't get fooled again!
  17. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,290
    586
    Netherlands
    loadbox + IR convoluter + wiresless headphones.
    should be just doable for 300$ if uou dont include the PC.
  18. dro
    Aug 1, 2015
    1,235
    2,153
    Blue Springs Mo
    I resemble that remark.
  19. Vinsanitizer
    Oct 19, 2012
    30,687
    27,706
    No miss boat: banana boat for you, two three scoop!
    Yessss... banana boat!
    SkyMonkey likes this.
  20. Marshall Stack
    Marshall Stack Well-Known Member
    Apr 15, 2011
    3,030
    4,476
    St. Louis, Mo.
    Why don't you just get a bedroom the size of a warehouse in an industrial park?
    Geeze likes this.
