Bass Became Over Powering and Boomy
Discussion in 'The Workbench' started by matttornado, Jan 27, 2020.
  1. Tatzmann
    Tatzmann Well-Known Member
    Nov 8, 2021
    547
    768
    Sorry didnt had time to read the whole thread,
    so if brightcaps has been suggested already
    then pardon my useless babblings.
    matttornado likes this.
  2. matttornado
    matttornado Well-Known Member
    Mar 14, 2012
    1,566
    1,086
    It's all good. That was a very good suggestion that I'm going to look into.
    Tatzmann likes this.
  3. matttornado
    Mar 14, 2012
    1,566
    1,086
    So I took a deep dive into this last night and confirmed that all caps on CB are good. Resistors all measured to spec.
    Voltages look good, bias is set at ~37mA (B+ was 480VDC). I do have one 6CA7 that measure 10mA less than the others no matter what socket it goes in. I matched that with the highest current draw tube to try and balance each side out.
    After much frustration and self disappointment, I grabbed a beer & took a break. I then decided to clean all of the input and output jacks with Deoxit and close it back up and test again.
    I played with a few different guitars and it seemed a lot better, especially when I cranked it. I have a PPIMV Rich mod. I hooked my attenuator up and cranked the master above half way to get the presence control to work and overall it sounded good except that I noticed that when I play single notes, they sound kind of choppy if that makes any sense?
    Either I'm a complete idiot or my mind / ears are playing tricks on me. I'm 52 years old so both are very possible. LOL
  4. Tatzmann
    Nov 8, 2021
    547
    768
    I wouldnt totally rule out that its just
    a changing conception of hearing, especially
    when diverse guitars are used, but in my
    experience if a good Marshall sounds bad
    at a given moment then something is wrong
    with it.
    These types of failures, if there is one, can drive
    one mental. I let these things go for a while and
    come back to it, but you already did.
    Man:(, i sometimes get one ear stuffed up a
    little bit this can throw things off too, often
    times i realize it first when its almost shut.
  5. matttornado
    Mar 14, 2012
    1,566
    1,086
    I played it this weekend and it still isn't right. It's like the overall voicing of the amp changed or something. IDK
