Bass Became Over Powering and Boomy
Discussion in 'The Workbench' started by matttornado, Jan 27, 2020.
  1. matttornado
    matttornado Well-Known Member
    Mar 14, 2012
    1,572
    1,091
    But how can the PI all of the sudden become reversed without anyone doing it?
  2. mickeydg5
    mickeydg5 Well-Known Member
    26,789
    13,978
    united States of America
    I am with @matttornado.
    Exactly how would a PI get reversed without modifying the board and or maybe the wiring?
  3. mickeydg5
    26,789
    13,978
    matttornado likes this.
  4. ampmadscientist
    17,859
    12,127
    I'm suggesting a test, it's a simple one.
  5. mAx___
    mAx___ Well-Known Member
    Apr 3, 2012
    574
    303
    This happened to me too not so long ago. I decided to try a new production Mullard in V3 of my amp and it killed the tone. Mushy, bassy, terrible sounding. Replaced it with an old one and the amp went back to normal. Glad yours is sounding great again.
  6. MickeyJ
    MickeyJ Well-Known Member
    Nov 11, 2019
    1,003
    574
    tests are over, well done getting it sorted, congratulations.
  7. matttornado
    Mar 14, 2012
    1,572
    1,091
    thanks for all the input everyone.
  8. matttornado
    Mar 14, 2012
    1,572
    1,091
    here's another observation:
    I said previously that everything seems fine now. The other night it sounded bassy again so I recorded it with my cell phone and it sounded way different all together but the bassiness was not there at all - not even close.
    I alos been noticing too, and this was suggested earlier in the thread, that my hearing has become very sensitive to lower bass frequencies. Especially with a cranked PA and vocals.....
  9. matttornado
    Mar 14, 2012
    1,572
    1,091
    Well, the problem is back again. Ugh :wtf:
    I'm going to re-read this thread and start troubleshooting. :rolleyes:
  10. Matthews Guitars
    5,315
    8,083
    You've got a loose connection in the amp or maybe a component is experiencing intermittent failures.
    That's going to take some time on the bench to troubleshoot. Not sure of your troubleshooting skill level, but for this it is going to take some good skills and some time to track down.
    It may be something as simple as a bad solder connection on the bright cap. Or it might be a failed mustard cap with ring cracks around one end, letting moisture get into the capacitor's guts.
  11. matttornado
    Mar 14, 2012
    1,572
    1,091
    thanks for your reply. yes it’ll be tough. I just finished measuring all of the voltages at every pin, for all 7 tubes. i’ll post them tomorrow at work. I have no leaking caps and all of the voltages look ok to me compared to a voltage chart i have from the metro forum.
    perhaps if you look at it, you might see something?
  12. Matthews Guitars
    5,315
    8,083
    Got a scope? It might be very helpful, particularly if you also have an audio signal generator and a cable to get it into the amp.
  13. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    3,016
    2,929
    Take off the attenuator and stop jumping the channels. Plug into the high treble channel. Does that make the bass less boomy and make the bass control act right?
  14. matttornado
    Mar 14, 2012
    1,572
    1,091
    thanks for the reply!
    Not using attenuator and not jumpered, bass control works fine as all other controls. I'm plugged into the high treble channel.
    The amp works great it just sounds very bassy especially when I palm mute the Low E and A strings.
    I always been able to jump the channels and crank the bass on 10 without it every being to bassy. been doing that for many years.....
  15. matttornado
    Mar 14, 2012
    1,572
    1,091
    I wish! I might grab one off of ebay.
    The problem with that is I don't know what I'm looking at, what looks good or what is bad. lol
  16. Chris-in-LA
    Jul 19, 2018
    3,016
    2,929
    That’s the opposite of my experience. Jumping the channels was always too dark for me, had to keep channel 2 very low. And I’ve never had any amps where putting the bass on 10 sounded good. Your current description sounds about normal to me.
    neikeel likes this.
  17. Chris-in-LA
    Jul 19, 2018
    3,016
    2,929
    PS, some closed back cabs really emphasize bass.
  18. Tatzmann
    Tatzmann Well-Known Member
    Nov 8, 2021
    574
    818
    I had similar problems in a 2205 couple
    years ago, drove me almost nuts, sounded
    perfect one day and the next time like boomy
    ugly horseshit. Was going through it with fine
    comb so to speak but couldnt locate the
    problem. I suspect compromised ceramic
    brightcaps, there are 2 in there directly
    on a socket which has over 500volts on
    the plates.
    I installed couple brightcaps and it sounds
    and feels like my 2203 now, so i keep it like
    that.
    Maybe check the brightcaps in your amp?:idea:
  19. matttornado
    Mar 14, 2012
    1,572
    1,091
    I either use an open back 2x12 Avatar with vintage 30's or an Marshall 4x12 with 25 watt greenbacks & I get the same results.
  20. matttornado
    Mar 14, 2012
    1,572
    1,091
    Thanks! Yep thought about that too. Will check into it - again.
    Tatzmann likes this.
