Anybody know what is happened to my AMP
Discussion in 'Marshall Amps' started by HiSaY, Aug 7, 2020.
  1. HiSaY
    HiSaY New Member
    Apr 10, 2020
    6
    13
    Hello all Marshall lovers,
    This is my JCM800 2203 in the video. The YouTube link below is will show my AMP error.
    I heard the sound like that a few days ago when I turn on my AMP. There is a noise whenever I knock with drum stick to the amp body and/or the circuit and no guitar sound is out. Like a loose connection, but I think it is not loose connection as the sound is there any where I hit with the stick.
    Please tell me if someone know what's happened?
    Thanks.
  2. SmokeyDopey
    Mar 9, 2011
    11,464
    7,122
    Argentina
    Could be a possible bad pre amp tube, but I'm not sure. And I don't even know if just a bad pre amp tube can cause that type of issue. I also hear a 100 Hz hum (something with the filter capacitors as well perhaps?)
    I'm not a tech so I can't really diagnose that.
    How do the tubes look? Any red?
    Do you have an extra preamp tube to swap out to see if that can be the culprit?
    Hopefully some techs will chip in. Good luck
    Mitchell Pearrow and HiSaY like this.
  3. rickc
    rickc Member
    Jul 7, 2020
    6
    34
  4. rolijen
    rolijen Well-Known Member
    May 19, 2019
    182
    538
    Most likely a bad tube.
  5. marshallmellowed
    Jun 26, 2009
    3,962
    5,122
    Yes, sounds like a bad tube. Only other thing I can think of, that would cause that type of noise, is dirty jack or tube socket contacts. I'd start with tubes, unplugging/plugging, then replacing (preamp first, then output).
  6. Jethro Rocker
    8,464
    10,494
    I'm betting a microphonic tube as well.
    Does it do this when the chassis is back in the shell? If not, why worry about it?
    HiSaY and tce63 like this.
  7. South Park
    2,880
    2,377
    You have a grounding problem . When you tap the amp you are going to ground . Check all grounds
    Mitchell Pearrow, HiSaY and tce63 like this.
  8. marshallmellowed
    Jun 26, 2009
    3,962
    5,122
    Try tapping "lightly" on each tube with a wooden pencil or chopstick. Do not tap the tubes hard, like you were tapping the chassis in the video.
  9. Maggot Brain
    Dec 13, 2011
    949
    1,585
    Seattle, Washington
    Sounds like a microphonic/bad tube to me.
  10. Jethro Rocker
    8,464
    10,494
    With a wooden drumstick?
    cozmacozmy, Trelwheen, HiSaY and 2 others like this.
  11. Matthews Guitars
    2,472
    3,550
    Put in your spare set of tubes and check it again. You DO have a spare set of tubes, right? If not, why not?
    If it's not the tubes or tube sockets then I'd give the filter capacitors a tap with a stick. If they're original to the amp then they're due for replacement.
    Being an early 80s amp they'd be LCR caps, apparently, and those seem to not have the same sort of ultra long life as the Daly caps used in the JMP era.
    But I'd also check every ground connection before changing out ANY parts.
  12. South Park
    2,880
    2,377
    First time I Sean a microphonic tube like that . Taping on the chassis not the tube . It would be hard to ground out a drum stick
  13. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,547
    1,273
    Who is this Sean person you keep mentioning?
    Trelwheen and tce63 like this.
  14. Neil Skene
    Neil Skene Well-Known Member
    Oct 3, 2011
    952
    1,591
    Australia
    It wants to be the worlds most EVIL theremin.
  15. maxxi
    maxxi Active Member
    Oct 9, 2011
    465
    249
    belgium
    I'm thinking grounding issue as well.
    change tubes first(the easy job), if not solved take it to a tech to get the grounding checked( or do it yourself if you're qualified).
    I find it somewhat weird that a microphonic tube would produce sound/noise even when the chassis/board is lightly touched with the drum stick, wouldn't it just amplify the vibrations of the chassis if tapped somewhat harder?
    just my thoughts, I'm in no way a qualified amp tech :hmm:
    South Park and HiSaY like this.
  16. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    946
    1,477
    You're not a drummer are you?
  17. HiSaY
    HiSaY New Member
    Apr 10, 2020
    6
    13
    I am not :)
  18. Seanxk
    Seanxk Well-Known Member
    May 14, 2018
    435
    373
    I have been known to be Microphonic, I sometimes repeat too.
  19. maxxi
    maxxi Active Member
    Oct 9, 2011
    465
    249
    belgium
    :rofl:
  20. pedecamp
    15,132
    12,636
    Clean all jacks, pots and tube sockets with Deoxit, see if that helps. Then take a known good preamp tube and try it in each slot to isolate which is the bad tube. If still no good replace the power tubes and rebias. If still no good tech time. Good luck with it and welcome to the forum, let us know how you make out. :yesway:
