Amp builds
Discussion in 'Building the Classics' started by Ricky Toney, Dec 2, 2021.
Tags:
where I can find a heybeor PT for jcm800
  1. Recomend
    0 vote(s)
    0.0%
  2. Recomend
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Ricky Toney
    Ricky Toney New Member
    Aug 27, 2021
    17
    I am building a jcm800 2204. With the broken chain I cant find part a needed. I have a heybeor OT and Choke, cant find PT would like to 15 to 18 tap for 12v dc
  2. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    3,016
    2,929
    Explain “would like to 15 to 18 tap for 12v dc”
    tschrama likes this.
  3. Chris-in-LA
    Jul 19, 2018
    3,016
    2,929
    Oh, did you want a standup or lay down type?
  4. Dblgun
    Dblgun Well-Known Member
    Jan 6, 2019
    350
    598
    AZ
    Probably looking for a standup if it's a 2204/JCM800 type chassis. As we all know transformers are kind of hard to come by currently. I've seen some 100w PT with a 15vac winding lately but nothing in a 50w. I certainly am not one who is "in the know" as to the current offerings. I'm sure Chris-In-LA or someone who is will be along soon and have a suggestion.
    South Park likes this.
  5. Chris-in-LA
    Jul 19, 2018
    3,016
    2,929
  6. Guitar-Rocker
    Mar 5, 2012
    3,096
    2,908
    Estero, Florida formerly from Indianapolis
    You could look at a DC heater supply pcb. I think Headfirst Amplification sells one of those, where you build up your own board. Other than something along those lines, a PT with that extra winding will be very difficult to locate.
    Ricky Toney likes this.
  7. Dblgun
    Jan 6, 2019
    350
    598
    AZ
    This is certainly true or you could get a transformer with a 5v winding and use it to power a small board. I did this in a recent project and it was simple and worked out well. Really opens up the possibilities for other transformer options. (Like JTM45)
  8. Chris-in-LA
    Jul 19, 2018
    3,016
    2,929
    Both of the PT’s I linked also have the 5v taps. What ever happened to OP?
  9. 2L man
    2L man Active Member
    Sep 30, 2020
    176
    118
    Perhaps there is room to install a toroid PT. I have made an aluminium plate to PT hole where toroid is screwed flat. Antek has many different output voltage 200VA tube PT for about $50. Amps I have used toroid PTs hum less than amps which use traditional EI core PTs but they are also cheaper and lighter.
    Here in europe we have quite a lot of toroid tube PTs available but in USA I know only Antek. Are there other?
  10. Ricky Toney
    Aug 27, 2021
    17
    Yes I want to use 12vdc on v1 v2
  11. Ricky Toney
    Aug 27, 2021
    17
    Stand up
  12. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    3,148
    3,174
    Las Vegas, NV
  13. william vogel
    Dec 18, 2016
    752
    880
    Why? The additional work involved will not improve the sound. I’ve gone down the heater supply wormhole and now I will always use 6.3 volts AC. Also, it’s not necessary to use a drill to twist 2 feet of paired wire down to 1 foot length. All that’s needed is parallel wiring in the shortest length to reach the sockets. 1 full twist in 2 inches is sufficient.
    Chris-in-LA likes this.
  14. Ricky Toney
    Aug 27, 2021
    17
    I guess I just want to try it on this new JCM 800 50W build. I float all the heaters on 65vdc that helps expecially with cathode follower life. This is my second build. My first was Jtm 45 and than I rebuilt into a dirty shirley so just trying to get more experience
  15. Ricky Toney
    Aug 27, 2021
    17
    I hade a real hard time finding a PT . I got one from Marsh and cant find any specs on HTS 7257. I am not sure what amperage it has. Will a 50w run on 120ma
  16. Ricky Toney
    Aug 27, 2021
    17
  17. Ricky Toney
    Aug 27, 2021
    17
    Thanks for info. I thought about using that model but I have the 27" chassis and with all the room I may try some channel switching and maybe midi.
  18. william vogel
    Dec 18, 2016
    752
    880
    I don’t know if a 120mA rated power transformer will make 50 watts. What’s the voltage rating? It will be mushy and that’s a good thing if that’s what you’re after. If you call Heyboer and ask to speak to Phil, he will pull the card and tell you the specs.
