Amp Attenuators
Discussion in 'Marshall Amps' started by TJB, Apr 10, 2021.
  1. FutureProf88
    FutureProf88 Well-Known Member
    Oct 2, 2012
    2,272
    1,719
    St. Louis metro area
    I mean.... I replace the tubes in my amps I play regularly maybe once a year. In my EL34 amps I just run JJ's and they're like $15-$20 ea? So $80 a year in power tubes. Who are you saving them for? I totally get the reluctance, as I have a lot of mechanical sympathy for my gear, but I don't sweat running stuff at 50-60%. Tubes are like brake pads on a car.
    anitoli and Ufoscorpion like this.
  2. tallcoolone
    tallcoolone Well-Known Member
    Mar 7, 2011
    1,863
    3,127
    NH
    Meh, the amp doesn't need it tho. I mean if you like the tone rock it but the JVM has a great master. Whenever possible, less is better.
  3. marshallmellowed
    Jun 26, 2009
    4,565
    6,676
    I've had 2 JVM's, and I've tried both through an attenuator. In my opinion, an attenuator is not needed with a JVM, or most master volume amps. I have several master volume amps, non-master volume amps, and several attenuators. I only see a need to use the attenuators with my non-master volume amps. I'd spend the money on something more useful. There you go, my opinion, for what it's worth.
  4. nubis99
    nubis99 New Member
    Dec 14, 2020
    13
    15
    not sure how much use you're gonna get out of an attenuator on a JVM, but depending on the attenuator you get you might need either a 16 ohm or an 8 ohm one, I seem to remember the TAD ones requiring an 8 ohm one for 2 16 ohm cabs. try and check the specs and manual before buying.
    edit: grammar is hard.
  5. FutureProf88
    Oct 2, 2012
    2,272
    1,719
    :D
    blue and tallcoolone like this.
  6. TJB
    TJB New Member
    Dec 26, 2020
    15
    14
    Thank you guys for taking the time to reply. I've decided not to spend the $900 + (with tax) on an attenuator. I as well as most of you here love my 410h amp and it does exactly what I need from it.
    Sustainium and tallcoolone like this.
  7. Monstercastle
    Monstercastle Member
    Nov 29, 2020
    55
    86
    NW Chicago Burbs
    Rockcrusher is $549 at Sweetwater.
  8. Manco
    Manco New Member
    Apr 5, 2021
    12
    13
    Hey there. I bought the Harley Benton PA-100 for 80€. What is the difference between this and the Rockcrusher?
  9. booh
    booh Member
    Apr 2, 2020
    18
    31
    Rockcrusher is more expensive! ;)
    I built different attenuators myself, love my Weber MiniMass (Weber has a reasonable price-performance ratio) and find most attenuators grossly overpriced.
    Chris-in-LA, Sustainium and scozz like this.
