Affordable tube amp
Discussion in 'Marshall Amps' started by superhooperduty55, Jan 4, 2021.
  1. superhooperduty55
    superhooperduty55 New Member
    Dec 31, 2020
    4
    i bought a MG30FX, last week, New Years Eve. Found it did what I thought were some strange things, like a fair bit of volume from speaker when gain was up about 1/10th of the way, both master volume and volume were down as far as they would go, took it base , Long & McQuade had a employee test it , I explained what was happening, but it worked fine for them, so I said I’d give it another try. Tried it again today , with gain set as before, master volume less than 1/2 way and volume set down as far has it would go, I got quite a bit of sound from speaker, I then turned up the volume, heard a clicking noise again turned volume down a far as it would go, no sound this time. Turned amp off, back on a same thing, sound from amp with volume off.
    Going to take it back, see if I can get it exchanged for a different model.
    Question do they make decent tube amp at a decent price, I jam jam at home, no playing for anyone else.
    Thanks
    Mitchell Pearrow and Old Punker like this.
  2. Cold Shot
    Cold Shot Well-Known Member
    Sep 27, 2020
    129
    256
    What's "affordable" to you? Peavey Classic 30's are super loud and you can snatch them up for $200 to $300 used all day long. I bought mine for $150 from a friend.
  3. fitz288
    fitz288 Apprentice Fermi's Paradox Analyst Silver Supporting Member
    Apr 7, 2020
    1,139
    2,318
    Pittsburgh, PA
    Try the master volume at zero, gain at 5, channel volume at 5 (both about noon).
    Strum a chord and slowly turn up the master till you get a volume you like.
    Cranking the master to half way and sending it no signal might be causing your "noise".
  4. Dogs of Doom
    23,515
    27,549
    DSL...
    If you like more '70s, try an Origin...
    The DSL will get you into early Metal territory no problem. It can do some semi-less distorted stuff too, but, it excels at the time around 1980 +/-. The Origin will get you that more classic tone.
    They make both in different wattages. The different watt will sound different. You might like one over the other. But, the overall tone from each line will be there, throughout the range.
    Lower watt will be cheaper.
    1 watt will be a lot louder than most think. 5 watts will get plenty loud for home use, 20 will get you into band territory & 50-100 will be gigging stuff...
    The Origin, relies on volume, so, if you go that route, you might think conservatively w/ power, so you can crank it. Warning, like I said about 1 watt being loud, 20 watts, will have your wife kick you out of the main house... :)... :wave:
    The DSL, you can turn them down (even the 100 watt) & they'll sound decent enough to play, even at whispers.
    W/ the Origin, you can always run a pedal up front to give it more gain...
    Anyway, either of these can be had under $500, if you shop right.
    Depending on your budget, there's quite a few more options moving up to the $1200-1300 range...
    scozz, jmp45, tomsvintage and 5 others like this.
  5. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,560
    3,961
    C-137
    Volume no issue?... 'Origin' -- all day.
    Need a master volume... 'DSL' -- will give you the goods.
  6. Seventh Son
    Seventh Son Well-Known Member
    Jul 24, 2014
    862
    974
    Naples, Florida
    DSL1CR or DSL5CR. Try them both, pick the one you like better, and never look back again.
    wakjob, SkyMonkey, Neptical and 2 others like this.
  7. Mitchell Pearrow
    13,304
    25,012
    I am with wackjob, and DOD but I am biased in this, because I have both, and they both get the job done.
    Cheers ...
    And
    Welcome to the forum!!
    Mitch
    jmp45, Dogs of Doom and wakjob like this.
  8. Neptical
    Neptical Well-Known Member
    Jun 13, 2010
    372
    804
    NH
    DSL50 or DSL100. Tones for days, very versatile. Own and love them both just as much as my JCM 900 SL-X 2500. Tighter, more refined even. Nab one while you can. I have a feeling these amps aren't going to be around at these prices for too, too much longer.
  9. superhooperduty55
    Dec 31, 2020
    4
  10. superhooperduty55
    Dec 31, 2020
    4
    Sorry I’m going to clarify my post. I do hear a lot of hissing noise, but what i’m Concerned about is, that with channel volume set as low as it will go, I get lots of guitar sound from the unit and it’s not consistent, one time with channel volume set down , no guitar sound, next time it has plenty of guitar sound, sorry i’m Not able to explain it more clearly.
    Thanks
  11. fitz288
    Apr 7, 2020
    1,139
    2,318
    Pittsburgh, PA
    I'm going to quote my self because I think you may have skipped over it.
    Turn the channel volume up and the master down.
    Tweek the channel volume/gain to taste.
    Control the output with the master.
    Report back with results.
  12. Jethro Rocker
    9,445
    13,152
    You are still likely ultimately better with a tube amp. Whats the budget? Try a DSL20 maybe or even the 5 watter. What style do you play?
  13. IOSEPHVS
    IOSEPHVS Well-Known Member
    Feb 10, 2020
    1,247
    1,516
    Ohio
    The best bang for the buck is the Origin 50. 50 watts of pure valve tone, with 50, 10, and ~5 watt modes. If there isn't enough gain for you in the preamp stage just put an EHX Hot Tubes (valve version) on the front end.
    Mitchell Pearrow and K2JLX like this.
  14. K2JLX
    K2JLX Well-Known Member Gold Supporting Member
    Apr 20, 2018
    393
    813
    The colonies
    this.
  15. dro
    dro Well-Known Member
    Aug 1, 2015
    1,013
    1,765
    Blue Springs Mo
    Haven't tried the Origin 50. Had the Origin 20h. Operative word here is Had. The 20 didn't ring my bell at all. Was looking for a smaller version of the Jtm45. The Origin (billed as a mini 1959) may well hit that mark. I've never had a 1959. And if the Origin is any indication, I don't need one. Have played a few DSL's supplied as backline. Wasn't impressed with these either. Then again I tend to have my own preferences. I think the term affordable tube amp. Is an oxymoron. Like Jumbo Shrimp. Save your ducketts. And get one that sounds good to you.
    Jethro Rocker and tce63 like this.
  16. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,660
    3,080
    I'm with @dro - save your money and keep looking. I tried to cheap my way - excuse me budget my way - in to tube amps. I also thought I could get the classic Marshall sound from Fender style amps [the internet promised me!?!]. Utter fail to my ears and I wasted $$$ and more importantly time chasing my tail. Stopped looking at price tags and started listening.
    The biggest aid was finding other amp guys who could answer questions about EQ and tweaking for my best sound. They had lots of amps to demo and I learned a bit about guitar playing too.
    Another shortcut was to look at what the bands were using to generate the tones I wanted. That narrowed the search significantly.
    Russ
    Mitchell Pearrow and dro like this.
  17. IOSEPHVS
    Feb 10, 2020
    1,247
    1,516
    Ohio
    The Origins should not be compared to a 1959. Sure, the 1959's patchable Lead and Bass inputs have been somewhat morphed into the Origin's tilt control, but the 1959 shipped with 5881 power valves and a GZ34 valve rectifier while the Origins use EL34s and a solid state rectifier.
    Still, the Origin, at least the 50, is very versatile. Its key is properly dialing in the EQ and Tilt controls for tone, and the Gain and Master controls for dirt. It can go from Fendery clean to heavy distortion, but I run mine clean with an EHX English MUFF'N (Plexi gain stage and tone stack) on the front end for distortion as needed. Also, a guitar's pickups have a big role with this amp. I would not buy the Origin for single coils, but it really sings with humbuckers.
    A JTM45 2245 (Made in England) sells for $2,600 while the ORI50H (Made in Vietnam) goes for $500, or $10 per watt. You'd be hard pressed to find a better deal in a good entry level valve amp. I think the JTM45 would be a better investment in the long term, but at the moment the ORI50H is holding its resale value nicely.
  18. donwagar
    donwagar Active Member
    Nov 24, 2018
    62
    155
    L&M are usually really good about bringing it back. It won't cost that much more to get into the low wattage DSL or Origin, take a test drive of them first.
    Also, check their Gear Hunter for a good used one in your price range. But remember if you find one in a different store, you have to pay the shipping. Bonus to used gear from L&M is you can put their warranty on it.
  19. Jethro Rocker
    9,445
    13,152
    Also what musical styles does OP play? They might have a good Traynor, maybe a used YCS50 or such. There is a good versatile tube amp although not Marshall.
  20. Headache
    Headache Well-Known Member
    Apr 19, 2019
    469
    1,148
    Old 100w peaveys,like the supreme, or even valveking.... the Marshall DSL, also the bugera 333xl is a decent, cheap copy of the JSX.
    If you hunt them you can find a great deal, be ready to spend 100 bucks on new tubes though.
