Is there a preferred method of phasing the filament string on a Superlead? Assuming one phase is red, the other is black, is there any benefit to alternating the color code on the different preamp tubes? For the output tubes I'd assume that you'd alternate their phase in pairs. Both outputs on the same side of the OT get the same filament phase.
No. There is only one phase in accordance to your supply. Did you wire your filaments into other phase? Explain?
i always do all of the power tube 2s one color and 7s the other color, all of the preamp tube 9s one color and 4-5s the other color
George Metropoulous likes to swap the phase from preamp tube to preamp tube for noise reduction purposes. I was reading about this, and that's what makes me ask the question. The filaments are run on 6.3 volts AC. I'm not doing DC filaments.
