8040 ValveState40 Combo: Reverb Impedance question
Discussion in 'The Workbench' started by Phil E, Oct 28, 2020.
  1. Phil E
    Phil E New Member
    Oct 26, 2020
    8
    4
    Got the word from Marshall and the reverb tank mounted on the board in the ValveState40 (8040) has the following impedances: 8.5 x 1.5 x 1ins IP=319 OP=2575 VERTICAL
    On the MOD reverb tank site they have 3 -- but they're listed as 310 in / 2575 out. I was always told that you could go into a higher impedance but never a lower. i.e., 4ohm->8ohm: Good | 8ohm->4ohm BAD
    or is the 319 ~ 310 in the acceptable range? Would it be bad to go with a 600ohm in?
  2. South Park
    3,120
    2,625
    That first part is the size of the reverb tank . I don’t think it has a impedance rating you can hook it up and see how it sounds . Ohm rating is a DC value impedance is a AC signal value . A reverb tank has no parts in it to impede the signal . The difference between 4 ohm and 8 ohm is not much
  3. Phil E
    Phil E New Member
    Oct 26, 2020
    8
    4
    Thanks for the reply South Park, but I'm pretty sure that every assertion you made there is wrong. ;-)
    All reverb tanks have Impedance values - look at the Product Info section here:
    https://www.modelectronics.com/reverb-tanks/sound-samples-product-info
    And PLEASE do not attach an 8 ohm load to a 4 ohm speaker (if there is just one) - not if you like your amp at least.
    SkyMonkey likes this.
