Hey all,
I am seeking forum advice for a pending speaker purchase for a Marshall Origin 20 head.
I am considering purchasing two Eminence XTC112-BT speaker cabinets (1x12) for use with the O20 Head. I may also use these extension cab(s) for my Blues Junior and DRRI combos to maximize use/versatility of these cabs.
The XTC112-BT speaker cabinet features "Parallel Jacks for Daisy Chain/Speaker Out" to enable two of these speaker cabinets to be used in parallel. If I’m not mistaken, I assume that I can equip 2 separate cabinets with one 16 ohm speaker each… the resulting load when daisy-chained together in parallel is 8 ohms total. Is that correct?
If so, it would appear that I would then have two options for connecting both 16 ohm cabinets at the same time to the O20 head as follows:
1) Connect to one of the O20’s 8 ohm speaker jacks out through a single speaker cable to the first speaker cabinet, and then connect (daisy-chain) the two speaker cabinets together with a second speaker cable. -OR-
2) Connect each 16 ohm speaker cabinet separately to the O2 Head's two “parallel” 8 ohm jacks designed to accept two separate 16 ohm speaker cabinets in parallel.
Using Option 1 above, I could then also connect both speaker cabs (in parallel) to either my Blues Junior or my DRRI, by-passing the combo speakers altogether if I so wished. Both the BJ and DRRI combos have stock 8 ohm speakers. If my assumptions above are correct, I should then purchase one 16 ohm speaker for each of these 1x12 Eminence cabinets. As of now, I am considering one Celestion G12M Creamback 65W and possibly an Eminence GB128 or similar (suggestions welcome in lieu of the EMI speaker).
Can someone please confirm my choice of 16 ohm speakers for use in these cabinets with either the O20 Head or my BJ/DRRI combos?
Is there any benefit/reason to go with an 8 ohm speaker for these cabs? In that case I assume I would then only be able to connect one speaker cabinet at a time to the O20 Head or to either combo. Is that correct?
I appreciate the help/advice. Thanks all… Regards
