68/69 Marshall plexi Superbass choke
Discussion in 'Marshall Amps' started by Adam Rogers, Jun 11, 2021.
  1. Adam Rogers
    Adam Rogers New Member
    Jan 25, 2021
    24
    Anyone know what the typical ohm values are for a late 68 early 69 Superbass? Getting what I think are pretty low readings.
  2. Matthews Guitars
    4,234
    6,376
    Ohm values aren't what matters. You need to be able to read the inductance.
    No worries, inductance meters are cheap enough. 20 bucks will get you a usable LCR meter.
  3. Adam Rogers
    Jan 25, 2021
    24
    Ok. My tech tells me the readings are low compared to what he's seen. perhaps I'm describing it wrong but I think he mentioned 32 ohms(?)
  4. Matthews Guitars
    4,234
    6,376
    What you want is probably a 3 or 5 Henry choke. Don't go by measured resistance.
    Check with Classic Tone or Mercury Magnetics.
  5. Adam Rogers
    Jan 25, 2021
    24
    Cool. Thanks much.
  6. Adam Rogers
    Jan 25, 2021
    24
    and what would the effects be of a shorted choke? there isn't any noticeable background noise.
  7. william vogel
    Dec 18, 2016
    612
    635
    Is the tech measuring the resistance with the choke removed electrically from the circuit? The choke should be about 105 ohms but if it’s in the circuit, the power transformer windings and the balance resistors across the screen filter capacitors are parallel resistance and will reduce the measured resistance.
  8. Matthews Guitars
    4,234
    6,376
    With a shorted choke, for one, the choke should run hot. But it'll cause all measured voltages in the amp to be higher than spec.
    Some amps don't have chokes. I've heard of some amps being modified to remove the choke. But if that's done then a ballast resistor needs to be added to control inrush current on power-up.
