50w Plexi build and considering adding options
ledvedder
New Jersey
I'm building a 50w Plexi, and I'm considering adding some of the switching options like Ceriatone's all access model. I'm curious which of these options you'd consider useful, and which aren't?
Tube/SS Rectifier Switch
Split/Shared Cathode Switch
Tonestack Switch
V1B Cap Switch
Bright Cap Switch
Presence Cap Switch
NFB Switch
Tonestack Bypass Switch
V2A Bypass Cap Switch
PPIMV
½ Power Switch
Buffered Effects Loop
Built-In Channel Jumper
BenTobith
I may be old fashioned, but I really prefer as simple a circuit pathway as possible.
Depends a lot on your playstyle, how you plan to use it, and what you’ll be using it for.
I could personally see value in a 1/2 power switch, depending on where you’ll be playing. But nothing else, really. For tube/SS rectifier, just swap between a tube and a SS rectifier plug-in if you want.
paul-e-mann
Tonestack Switch
V1B Cap Switch
Bright Cap Switch
Presence Cap Switch
NFB Switch
PPIMV
½ Power Switch
One of guys here is building that exact amp right now, look for his thread, wait til hes done and he can give you first hand info whats good and whats not.
