This must have been asked before, but I can't find quite so direct an example!
Given that the traditional Marshall rock tone is a 4x12 loaded with Greenbacks, the blend of the two (format/speaker) fills out the greenback bass response, gives it some push, allowing the top end to shine as well, poss through some phasing phenomena (amongst prob loads of other factors)
Using a single greenback in a 1x12 has its uses, but overall you get exactly what a greenback is, woolly lows, very middy (nasal?), early breakup, low power handling
That might be fine for your purposes, so it isn't a critique.
Given I have a single 1x12 cab from Lean Audio (Montage), well built, good size and materials.
Which other speakers can get close to, or are described as, that greenback 4x12 tonality with a 50w Plexi head.
Am very aware they are different things, so not likely to get exactly, but some tonal qualities must get close ?
The Creamback 65 is described as a higher power greenback, but still for either 4x12 or 2x12 cabs with the same basic greenback tone?
The Creamback 75 might be closer as it is an H magnet giving that extra bass that is missing from not being in a 4x12 cab ?
The g12-65 is similar to the above I think?
I had a Heritage g12H55 that I liked in a 1x12, maybe the 75 ?
Others like the V30 I will steer clear of form various moans about ice pick etc !!
If it's a stupid question please say so as well of course, am still learnin' !!
