4-wire pickup issue with splitting the coils
Discussion in 'The Tone Zone' started by Macro, Mar 24, 2012.
  1. Macro
    Macro Well-Known Member
    Jul 10, 2011
    2,549
    2,041
    The land of cheesesteaks and soft pretzels
    Talking about Seymour Duncan pickups specifically...
    On the duncan 4-wire humbuckers, the color codes are as follows...
    I want to set up a switch to select either side, or both in series.
    Im starting out with just a simple practice amp and a patch cable. (wanted to check my wiring before hooking anything up)
    When I connect the green lead to the common wire of the cable, and the red wire to the tip, I still get sound out of both sides of the humbucker. In this case, the south side is louder and more prominent than the north, but the north is still making noise (even though the white and black wires are unconnected to anything)
    The opposite happens if I connect the black and white leads to the patch cable....the north is louder but the south still 'picks up' noise.
    At first I thought something was wrong with the pickup, so I tried another one I had....same issue. (and these are both brand new pickups)
    What is going on?
    I really want to be able to get three options out of the humbucker....the north, the south, or everything in series for full humbucker sound.
    What am I missing?
  2. LuredMaul
    LuredMaul Active Member
    Dec 30, 2009
    784
    158
    what pickup?
  3. LuredMaul
    Dec 30, 2009
    784
    158
  4. Macro
    Jul 10, 2011
    2,549
    2,041
    That is a pretty awesome site....thanks for sharing the link.
    Unfortunately, I cant get the issue to work with just the pickup and a cable...getting into the switching configuration is a next step...but I need to figure out the first step first.
    I cant isolate the north and south coils...im wondering if one is inducing the other....if the wiring diagram is accurate, when I hook up one coil, the other is completely unwired to anything. I dont understand how it is picking up anything...the only possible connection would be magnetic field....there is no physical connection between conductors (that I know of)
  5. brp
    brp Well-Known Member
    Nov 11, 2010
    5,265
    2,846
    Vancouver, Canada
    How are you sure that it is? Not by tapping the poles on the coil you expect to be not functioning I hope.
    I couldn't find the S Duncan diagram for what you are doing but here's the diagram for Dimarzio for what you want to do
    http://www.dimarzio.com/sites/default/files/diagrams/1humdpdt_lcoilseriesrcoil.pdf
    You can use this diagram but just change the wire color to the appropriate ones for SD 4 wire pickups using this key:
    Dimarzio red = SD BLACK
    " " black = SD WHITE
    " " white = SD RED
    " " green = SD GREEN
    Double check this code key for yourself here:
    Guitar & Bass 4-Wire Humbucker Color Code Diagrams
    Or just use this one
    http://www.guitarelectronics.com/pr...bucker1-VolumePull-for-South-Single-Coil.html
    if you know what the wires for each coil are for SD 4 wire pups.
    Hope this helps.
  6. Macro
    Jul 10, 2011
    2,549
    2,041
    The method I have always used is to hook the pickup wires to a guitar cable, plug into an amp on clean channel on low volume, then touch a paper clip to a pole in the coil I am testing and gently slide it around on the surface. If the coil is hot you hear a scraping noise through the speaker...if the coil is dead, you might get a very faint noise picked by another active coil, but it's clearly not 'picking up'
    With the pickups in question, the 'dead' coil is absolutely picking up...it is microphonic without question....I've triple checked the schematics for the pickups....it's standard 4 wire (and I know the start and finish for each coil). At this point I m wondering if I could have two pickups that simply have a short among the windings somewhere within the bobbin. I can't rationalize any other way this is happening.
    I even tried to ground both ends of the coil for the side I don't want picking up....and it still picks up noise.
    I think I need to pull a pickup from a guitar th works correctly....if I get a chance I'll do this later today.
  7. Micky
    Apr 29, 2010
    21,037
    17,683
    Vermont
    Have you put a meter on the coils yet?
    Any chance you have the wire color code different?
  8. Macro
    Jul 10, 2011
    2,549
    2,041
    I am getting about 8.1k ohms across each coil...the color coding I am working from appears to be correct. I am seeing around 2-3M ohms of resistance in the isolation between the two windings.*
    When I individually connect the coils to an amp, you can hear a clear difference between the active circuit and the coil that isn't physically connected...still, the induced coil is picking up noise...not much, but it's there.
    This is the first time I really picked apart a 4 wire humbucker on the test bench....guess I was expecting absolutely isolated coils. In my perfect world, until I physically connected the end of one coil to the start of another, the two would have no electrical relationship. In my case, it appears that the isolation isn't 100%. A few mega Ohms is pretty decent isolation, guess I just expected it to be infinity :)
    I'll wire this thing up with my DPDT switch when I get a chance. Hoping that once everything is soldered up properly (and all the associated grounds are established) that the isolation will be more apparent.
  9. JohnH
    JohnH Well-Known Member
    May 31, 2008
    4,133
    2,093
    Wilton NSW
    Definately measure with a multimeter to make sure you are getting about half the resistance in the split modes.
    But you will get magnetic coupling. If you connect to one coil only, and tap the other one, you will get a sound because they are all within the same magnetic field. Its normal, but the connected coil will be stronger and you will still get a more single coil sound.
  10. Micky
    Apr 29, 2010
    21,037
    17,683
    Vermont
    I think you are experiencing the 'humbucking' effect, where the other wind is actually being induced as you have observed. Hopefully Rayne will chime in here and pick this subject apart for us.
  11. MajorNut1967
    MajorNut1967 New Member
    Jul 30, 2009
    3,883
    338
  12. MajorNut1967
    Jul 30, 2009
    3,883
    338
    Use a SPDT 3 position on/off/on
  13. Macro
    Jul 10, 2011
    2,549
    2,041
    The resistance is pretty much spot on....16.2k across both coils in series...8.1k individually. And I think you are right....it appears that the unconnected coil is simply within the active field. Probably a function of the pickup itself...the Seymour Duncan hotrails is a small package with a lot of wire...lot of field across two rails that site about a centimeter apart.
    I think all is cool...just need to wire it up and see what it sounds like in the guitar, and not worry about meter readings on my bench :)
  14. Macro
    Jul 10, 2011
    2,549
    2,041
  15. Macro
    Jul 10, 2011
    2,549
    2,041
    Actually using a DPDT on on on
    Easier for the specific application I have in mind.
    The circuit design was the easy part...my issue was more a matter of the pickup construction.
  16. MajorNut1967
    Jul 30, 2009
    3,883
    338
    No on/off/on
  17. Macro
    Jul 10, 2011
    2,549
    2,041
    The circuit I designed uses an on-on-on switch.
    How would you use a 3-way on-off-on to accomplish the following...
    Position 1 - one half of the humbucker active
    Middle position - full series humbucking
    Position 3 - the other half of the humbucker active.
    In the middle position I want series wiring, not parallel.
    Seems easier to do this with an on-on-on
  18. JohnH
    May 31, 2008
    4,133
    2,093
    Wilton NSW
    You can use on-on-on, or on-off-on, with the wiring to suit. Acyually, the on-off-on one is simpler, since you only need half of a dpdt switch, but either can work fine.
