2x12 cab build
Discussion in 'Cabinets & Speakers' started by Marcomel79, Sep 22, 2021.
  1. neikeel
    6,403
    5,298
    You mean like the top one here that I built?:
    I could be tempted to sell as part of my 'rationalisation'!
    jmp45, Marcomel79 and fitz288 like this.
  2. fitz288
    Apr 7, 2020
    3,521
    8,582
    rahndahbaht dah 'Burgh
    No grill cloth "rattle" that I'm aware of.
    I stretched the cloth right across the baffle plates.
    I was getting a low frequency vibration (farting) with the completely closed cab.
    May be from the 5/8" plywood, or just my home made design?
    As with the speaker offset, it was a lot of guessing, and zero acoustical engineering.
    But when I cut 4 port holes in the back panel, it went away. :shrug:
    Marcomel79 likes this.
  3. Marcomel79
    Marcomel79 Well-Known Member
    May 3, 2021
    449
    492
    Oslo
    Ok.... i used the measurements for the SV20H cab so i Hope it will be ok.. do you mind sharing pics of those port holes?
    fitz288 likes this.
  4. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    Thats beautiful! The knobs are also really cool.
  5. fitz288
    Apr 7, 2020
    3,521
    8,582
    4 holes - used a door knob hole saw (2-1/4")
    Attached a black metal mesh on the inside to keep stuff from falling in.
    I tried taking everything apart, looking for loose parts. and adding more fasteners to the baffle frame, but the vibration continued.
    My MX112s & 6912 cabs are front ported, the Haze cabs are not.
    More total guessing, but I decided to try the holes, and it seemed to work.
    I've also since changed the speakers - perhaps the V30s were a little bass heavy?
    I would say build you cab as planned and try this only if you have a similar problem.
    Your MDF may not have a vibration like my plywood.
    jmp45, BlueX and Marcomel79 like this.
  6. Mjh36
    Mjh36 New Member
    Nov 27, 2020
    10
    16
    That's some really pro looking work you guys are doing. Exactly what I'm trying to do. Thanks for the answer about the baffle joints, that makes sense now. I was going to show you pics I found of the beveled cleat bracing that I had seen elsewhere, but @fitz288 got it covered. Vertical slanted 2x12's are my fav type of look.
    In my ambition however, I keep forgetting the speaker holes and beveled corner edges, I have no tools for that. Someday soon though... I may just get a used 2x12 cab and re-tolex/re-speaker it instead.
  7. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    Btw the marshall plaque on the top amp is one of the coolest ive ever seen!
  8. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    Looks very nice man! Love what you did with the extra grill cloth. And the tolex job is spot on! Im also gonna use bronco for mine. So you took out the V30? What speakers did you put in? Im guessing for mine its gonna be perfect, closed back with two greenbacks. If not, ill do exactly like you did. Was thinking of how i was gonna use the extra tolex from the head build, but i dont use any pedals... btw the origin head looks a bit taller than the sv20h, just like mine...
    fitz288 likes this.
  9. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    I notice only now that the second head from the bottom is green! Noice!
    Dogs of Doom likes this.
  10. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    I dont have many tools, but a friend of mine does... you always find somebody that can help you...
  11. fitz288
    Apr 7, 2020
    3,521
    8,582
    I started with 2 v30's, then I put a T75 in the top, then I moved both of those to the MX112 cabs for my DSL20H.
    Now I have a pair of old G12T-66's in the Origin 212 (Celestion - Marshall Marquee speakers from the Haze amps)
    I have no idea of what they would compare to from current production models.
  12. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    Ok so more progress tonight on my build, although it always takes longer than one thinks... thank you @fitz288 for sharing your pictures so i could get an idea on how to solve this puzzle, although mine didnt come out as clean yours.
    04F36060-2DD6-44BC-A248-8BB8F698029C.jpeg C9AB1986-A17D-440B-974B-83140B32F1F5.jpeg 82B8420B-470A-4181-93EE-DB10F292C065.jpeg 30D57E58-C913-4075-BE3C-608DAF36589E.jpeg D4F0731C-6759-4B56-B6D7-4943430690BC.jpeg B0D3DCED-2D61-4266-9E3B-414499AC2256.jpeg A247035C-62C6-4780-B7EF-BCA5BB73D94B.jpeg
    fixed my pics being uploaded sideways... anyway, yes, a lot of screws.... the ones on each side of where the baffles meet wont be visible because im planning to run a frame around both sections of the baffle, to space the grillcloth from the baffle itself, so that it will eliminate any possible "cloth rattle", which with my luck, id probably get if i didnt do it. The screws all the way on the sides are temporary, to keep the baffle in position while glue dries. Excuses excuses....hopefully it will be finished sometime next week so i can test it. Over and out.
    neikeel, jmp45, BlueX and 4 others like this.
  13. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    So last night i got done with my cab at my friends workshop and brought it home. I still need to fine tune it but now i can do it at home and can work on it little by little until its totally ready. Here are some pics
    6E5D022C-5E50-4EB9-86A0-9786D10784A5.jpeg back panel cut
    08BC39E9-AE8B-4FEC-AE2D-EE51B1E4ED40.jpeg 6A5C519A-C11E-4514-9970-A2058C52FF3C.jpeg Close up of trim strip channel done with just the width of the table saw blade (3mm), And 3 mm deep, which is just perfect
    65346879-A636-44B3-B265-119F5D3747F4.jpeg I went ahead and installed a frame around the baffle against baffle cloth rattle (good name for a song!) 7EBE04FF-7A0A-452E-BF00-7EA568B283AA.jpeg F556E528-873F-4BAD-B65A-1D0B3F6CA54C.jpeg ...and here is a view with the head i built some time ago. Still need to drill the holes for the back panel and attach the baffle to the cab but got very late last night and we had to call it a day. Tolex, bells and whistles will have to wait for now. Ill maybe post a little video when i finally hook it up to show how it sounds. Thanks for looking.
    Marco
  14. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,915
    3,954
    Nice attention to detail - bracing angles and general fitment of the pieces!
    Don't you just want to throw in some speakers and let it rip?!
    Russ
  15. BlueX
    BlueX Well-Known Member Silver Supporting Member
    May 5, 2020
    181
    432
    Sweden
    Thanks for the progress pic's, looks nice!
    I would be eager to mount speakers and try it out.
  16. fitz288
    Apr 7, 2020
    3,521
    8,582
    I would do this.
    Not just for the fun of it, but check the acoustics and see (hear) if you think any modifications are necessary before you get further into finishing details.
    And for the fun of it.
  17. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    Thanks @fitz288 thats exactly what im gonna do! Also found that i need to cut a slot on the inside brace that goes along both baffles as i realized theres not enough clearance for the speaker... same on top... you live you learn.. but yeah, need to save up for tolex and co. So i will be testing the cab naked for now
    fitz288 likes this.
  18. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    Thanks Russ, coming from you is a great compliment. I tried to copy from @fitz288 and his cab build...Theres a few minor things i need to do before i throw in some speakers but believe me, i cannot wait to try it out. With small kids i can only work few hours per night. Hopefully tomorrow i can fit one of the speakers. The other one is coming in a week
    Geeze likes this.
  19. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    2,761
    2,798
    What's with the cage thing in the corner? Extracurricular activities with the spouse?
  20. Marcomel79
    May 3, 2021
    449
    492
    Oslo
    Hahahaha its some kind of crib my friend had built for his son... get your mind out of the gutter!:D
