2203 vs 1959 voicing question
Discussion in 'Let's Talk Vintage' started by Matthews Guitars, Aug 13, 2020.
  1. Matthews Guitars
    2,696
    3,957
    I don't know why I didn't notice this before, but I've found that my 1959 (1973 manufacture, and freshly rebuilt and restored) has a much more pushed midrange than my 2203. (1978 manufacture, more or less original other than having been recapped at some point. )
    Usually I pick one specific guitar for each amp. I didn't notice that the voicing change was really
    in the amp until I just got too lazy to pick up the other guitar and simply ran one guitar into both amps.
    The 1959 has a distinctly honky/quacky midrange compared to the much more scooped sound of the 2203.
    Normal, or not normal?
    dptone5 likes this.
  2. South Park
    2,986
    2,498
    You have to look at the schematic and look at the tone caps and The gain of the preamp . And how the frequency’s are rolled of .
  3. AlvisX
    AlvisX Well-Known Member Gold Supporting Member
    May 31, 2011
    4,899
    9,838
    I-55 Corridor
    My experience, the 2203's are much brighter due to the peak caps and brite brite cap (over the top IMO) . I tune mine way less bright
    1959 should be middy ,that's the good Marshall tone man
    FogDweller and wntbtw like this.
  4. Matthews Guitars
    2,696
    3,957
    That pretty much is the right description of what I'm hearing.
    Next time I open the chassis for any reason I'll be taking notes on component values, bright caps, etc.
  5. RobS
    RobS Well-Known Member
    Apr 19, 2009
    990
    276
    Melbourne - Australia
    i tried the bright cap snip on my 2203x many years back and soldered it back in as I found the amp lost some of its character, yeah it did sound very much warmer and at first I really liked it but that was at home / low volumes.
    Once up to normal playing levels with bass & drums it didnt cut through like previously, even with treble & presence up very high
    Are you trying to achieve the same sound from your 2203 as the 59?
    Oddly enough I found that running a cooler bias 50-55% on my 2203x really warmed up the sound of my amp as opposed to a hotter bias in the 60-65% range and now am really happy with the way its sounding.
  6. dptone5
    dptone5 Well-Known Member
    Jan 31, 2010
    5,379
    4,269
    Pennsylvania
    Matt, I have a 2203X and 1987XL. I agree with your assessment 100%. Both are great to have and record with, depending on the application, however, I tend to gravitate more to the 2203X sound. It's my favorite head.
    FogDweller likes this.
  7. AlvisX
    May 31, 2011
    4,899
    9,838
    I-55 Corridor
    Somebody ,somewhere started this "snip" thing , but that was never the answer.
    My solution is to "tune" rather than snip .
    What I like best these days on the fly , is to lift a leg on that 470-500pf peak cap on the board, Remove the 470-500pf peak cap over the resistor coming from the input jack , remove the brite cap on the over the pot , replace it that 470-500 pf cap that I removed from the input resistor.
  8. neikeel
    4,728
    3,136
    Something I came across when tuning an AFD type amp was simply piggybacking a 1800pF across the treble peaker between the hi and lo jacks it brings a lot more upper mids in and makes the other caps less sharp and bright. I recommend you give it a whirl (if you have not already).
  9. AlvisX
    May 31, 2011
    4,899
    9,838
    I-55 Corridor
    Dammit man , now I gotta carry an 1800pf cap n gator clips for the next time I gotta use someone else's 2203/4 :lol:
  10. Fusedbrain
    Fusedbrain Active Member
    Apr 28, 2014
    222
    99
    Mississauga Ontario
    .680uf presence cap in the '73 1959?
