2203 tone cap identification
Discussion in 'The Workbench' started by Dominic Lampron, Sep 24, 2020.
  1. Dominic Lampron
    Dominic Lampron Member
    Feb 2, 2020
    121
    2
    Can anyone help me identifying the bass and mid cap in the tone stack of my 2203 JMP? Is 1=bass and 2=mids? Am i right? Thanks!
  2. South Park
    3,006
    2,518
    I don’t think those are in the tone stack . 022uf coupler caps
  3. neikeel
    4,745
    3,144
    those are the 0.022uF 400v mustard caps that couple to the EQ pots. Tone stack cap is the ceramic disc just next to them. Typically 470pF or 500pF.
    The ceramic disc further across is the bright channel mixer bypass cap (really another treble peaker as in this circuit the non-bypassed resistor is grounded
    Dominic Lampron likes this.
  4. william vogel
    Dec 18, 2016
    337
    278
    To answer your question. 1 is bass and 2 is mid. Follow the Pink wire If it goes to the middle pot, 2 is mid and if the brown wire goes to the treble pot, 1 is bass.
  5. Dominic Lampron
    Feb 2, 2020
    121
    2
    Ok! Thanks! But according to the Duncan TSC, those 2 mustards caps are acting in bass and mids and when changing values, the EQ response change... Also, for the bright cap, what will it do for the tone of the amp if i lower the value? Will it be like the treble cap? (i’ve swap the 470pf for a 220pf to change the treble EQ sweep, much less agressive!)?
  6. Dominic Lampron
    Feb 2, 2020
    121
    2
    thanks!!
