Dominick Pascarella
- Joined
- Feb 9, 2020
- Messages
- 77
- Reaction score
- 32
If I run 2 16ohm cabinets into one input via y-cable, how many ohms would I connect this to on the amp?? 16ohm? Or 8 ohms??
That depends on how the Y cable is wired.If I run 2 16ohm cabinets into one input via y-cable, how many ohms would I connect this to on the amp?? 16ohm? Or 8 ohms??
This is the answer, hook up the 2 cabs with said cable, and put a meter on the end to get a resistance reading.I'm also not sure what the total impedance would be without putting a multimeter to the Y cable to test.
Read up on Ohms law that way you will find the answer, but in this case i will tell you what you need to know and that two 16Ohm speakers in parallel will give you 8OhmsIf I run 2 16ohm cabinets into one input via y-cable, how many ohms would I connect this to on the amp?? 16ohm? Or 8 ohms??
We have to assume that the Y connector connects cables in parallel, never know one to connect in series, but as long as in this case the cable is connected to an 8Ohm output on the amp then all will be fineSo the cable itself can be wired in either parallel or series? I have not entertained this thought before. Interesting.
I'd say probably parallel, but I wouldn't assume.We have to assume that the Y connector connects cables in parallel, never know one to connect in series, but as long as in this case the cable is connected to an 8Ohm output on the amp then all will be fine
I suppose I should have stated "speaker" cable.@fitz288
Be careful throwing around the term "balanced cable" as it actually means something quite different in the audio world than what you are intending. A "balanced" cable is typically two conductors and a shield/drain/ground conductor, and utilizes three conductor connectors (like a microphone cable), typically XLR or tip/ring/sleeve for carrying "balanced" low impedance mic and line level signals. Where pin #1/sleeve = shield/drain/ground, pin #2/tip = +/positive and pin #3/ring = -/negative. I do however, get your thought of wanting the +positive and -negative wires to be the same size/gauge, although this is not typically referred to as balanced!
It should also be noted that there are many cables that appear to be "Y" cables, but actually perform very differet functions. One example is intended as an "insert" cable for send and return on mixing consoles and/or "splitter" for a stereo signal to two mono. This cable typicaly has a three conductor, Tip/Ring/Sleeve plug (1/4 inch or 1/8 inch) at one end, going to two separate, two conductor, Tip/Sleeve or RCA plugs. One of those two conductor Tip/Sleeve plugs is connected to the Tip and Sleeve of the Tip/Ring/Sleeve plug and the other two conductor Tip/Sleeve plug is connected to the Ring and Sleeve of the Tip/Ring/Sleeve plug. This cable configuration is also quite often used to "split" the left and right to two separate plugs, from a stereo headphone output. This will not function as a "Y" cable and should NEVER (as with any shielded cable) be used for speakers!
When one desires operating two speaker cabinets in parallel (without installed provisions for doing so), the best way is to build a small "all parallel" box with three Tip/Sleeve jacks, all wired together in parallel. Then simply run one actual speaker cable from the amp to the box and one speaker cable from the box to each of the two speaker cabinets. This provides a solid parallel set of connections, with no guesswork.
For amp to speaker interconnections, I "ALWAYS" use simple zip wire/lamp cord (minimum #18, but usually #16 gauge) for the cable. Cheap, easy to work with, very durable and will never get confused with a signal cablel!
The yellow one below has seen +35 years of regular use! I wish yellow zip was still commonly available. White and brown is typical, but just after the Christmas holidays, green and red zip wire extension cords are often available at fire sale prices! FWIW, cheap extension cords are a great resource for #16 gauge zip wire, in brown or white!
Just Cablin'
Gene
You woudn't use a Y cable for speakers. But a lot of cabinets have two jacks which will be in parallel if there's no stereo/mono switch with the jacks.
I was thinking this too. But something about the crotch of the Y cable flexing all about, regardless of construction quality, while my $2,000+ amp is hooked up to it just doesn't fly with me.There is nothing wrong with a "PROPERLY CONSTRUCTED" Y cable for speakers
I'm going to make an uneducated guess here and assume the cable is a speaker cable and not an instrument cable and that it is wired in parallel - my answer would be 8 ohms just like if you plugged these two 16 ohm cabs into the speaker jacks of an amp head.If I run 2 16ohm cabinets into one input via y-cable, how many ohms would I connect this to on the amp?? 16ohm? Or 8 ohms??
If in parallel, 8 ohms. Parallel means +with + and - with -If I run 2 16ohm cabinets into one input via y-cable, how many ohms would I connect this to on the amp?? 16ohm? Or 8 ohms??
Hello, Dominick!If I run 2 16ohm cabinets into one input via y-cable, how many ohms would I connect this to on the amp?? 16ohm? Or 8 ohms??
Please explain.Don’t use a y-cable for speakers! Never! Don´t do it! I will kill your amp sooner or later by causing a shortcut.
I disagree... A well done, properly soldered cable will be fine.Don’t use a y-cable for speakers! Never! Don´t do it! I will kill your amp sooner or later by causing a shortcut.
{snip}
And do not use a y-cable!
