Overtone85
- Joined
- Jul 27, 2018
- Messages
- 10
- Reaction score
- 1
Long time lurker, first time poster.
I have a couple of plexi/jose builds under my belt and I am servicing my friend's 2210.
It had original LCR caps.
The amp came with a failed PI tube so I replaced it. When I turned it on it had a background hum, loud enough to be very annoying whem playing the amp at bedroom volume.
Also, the hum is most noticeable when all volume controls are at zero, gain at zero on the dirty channel. The hum affects the clean channel as well.
I thought it was the filter caps so I proceded to replace them with F&T caps. I also reformed the new caps properly with a current limiting resistor until the voltage drop was under 2v.
I cleaned the pots, input and output jacks.
I replaced the bias caps with new 10uF 100v electrolytics
I replaced the main 3300uF 6.3VV filter cap on the switchign circuit supply.
The power tubes are healthy and I rebiased them at 65% plate dissipation.
I fire the amp up and the background hum was still there. So I started removing all the preamp tubes one by one, starting from v1. Nothing was changing until I got to the PI.
With the PI in the amp, there is still hum. When I pull the PI abnd just leave the power tubes, the hum goes away.
I scoped the B+ line. Except the residual ripple after the first filter stage, the DC is flat and clean after the choke.
I found a thread in another forum where a guy had the same amp, same exact problem, ( no PI, no hum ) and he discovered a loose ground lug under the board.
So this morning I lifted the board and I did not find any loose ground lugs, they're all pretty solid and continuity meausres fine.
So I proceded to reflow all the solder joints under the board. Found some dirty connections on the reverb return tube socket and reflowed them. I reflowed the ground wire that is part of the shielded wire going to the fx loop and then to the chassis bolt that is fastening the reverb transformer.
I also cleaned the chassis where the pots nuts are supposed to make contact with it.
After all of this the hum is still there.
If I jumper the 2 grids of the PI, the amp is completely silent.
The wires going to the FX loop recovery stage are a bit microphonic when I tap them.
I measured all the preamp tubes with my Orange valve tester and they all seem fine. Pplus, if the hum is still there even with all preamp tubes pulled , they must not be the cause.
The only components I have not replaced yet are the small electrolytic on the preamp cathodes and switching circuit.
I forgot to mention taht all of this happens both with guitar plugged in and not plugged in.
One last thing. If I keep the amp in plying mode (off standby) and turnt the power switch OFF the hum goes away instantly and I just hear the hiss of the preamp fading as the filter caps discharge.
Apart from all of this the amp sounds great.
Any suggestion are highly appreciated.
Cheers
Cheers
