1959SLP vs. JCM 800
Discussion in 'Marshall Amps' started by JM5010, Jul 4, 2020.
  1. JM5010
    JM5010 Active Member
    Nov 11, 2017
    187
    26
    I’ve been researching the Dookie Mod and was told by someone who has worked on Billie Joe’s amps that “JCM 800’s aren’t ideal for the mod”
    What is the difference between a 1959SLP and JCM 800?
    I know JCM 800’s are MV amps while the other isn’t. Are the voltages different, etc?
    What makes a 1959 more suitable for mods?
  2. scozz
    scozz Well-Known Member
    Jul 20, 2008
    3,631
    8,211
    Assuming this Tech is right, and I have no reason to believe otherwise, I’ve heard that the MV circut could/does affect other functions of an amp, like an effects loop.
    That doesn’t answer your question though, does it.
    But could it be because of the MV? That’s really the biggest difference in the two amps,...
    Someone more knowledgeable than me will come around soon, but this gives you a little bump.
    tce63 likes this.
  3. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    882
    1,906
    WA state hinterlands
    JCM800 has an extra gain stage on the Hi input. Here's how it works...on the 1959SL each input I and II uses one half of V1 the first preamp tube, then the guitar signal heads over to the 2nd preamp tube. The JCM800 Hi channel uses both halfs of V1. Guitar signal travels to V1b, across the Preamp pot to V1a e.g. 2 gain stages, then over to the 2nd preamp tube.
    neikeel, Kelia, dptone5 and 5 others like this.
  4. AlvisX
    AlvisX Well-Known Member
    May 31, 2011
    4,689
    9,084
    I-55 Corridor
    JCM 800 is a production series ,not a model
    There is a JCM 800 1959 ,just like there is a a JMP 2203 .....
    I know sh*t about Billie Joe ,'cept he bought a Junior out from under me once
  5. JM5010
    Nov 11, 2017
    187
    26
    This too. But let’s say a 1959 is modded so that it has the exact same gain stages as a 2203. Would they sound the same?
    I’m thinking maybe the voltages and transformers are different in both amps.
  6. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,356
    1,099
    They use the same tubes. My bet is that if you take a 1959 and do the jcm800 mod to v1 it would sound very close to a 2203.
    neikeel and wntbtw like this.
  7. coolidge56
    Jan 30, 2019
    882
    1,906
    Remove a couple caps, change a resistor and wiring and the 1959 becomes a JCM800 2203 in an afternoon. There's not much difference. Ditto for the transformer voltages, though voltages for each have varied over the years depending on year and model. If I built a 1959 then converted it to a 2203 there would be no need to change transformers. You end up with 2 unused input jack holes, a Preamp/Master instead of Vol 1/Vol 2.
    JM5010, WellBurnTheSky and scozz like this.
  8. LPMarshall hack
    Nov 18, 2009
    10,829
    10,110
    San Diego, CA
    I’d like to hear that story
    JM5010 and Mitchell Pearrow like this.
  9. Mitchell Pearrow
    11,070
    19,095
    Me too
    :agreed: :cheers:
    LPMarshall hack likes this.
  10. Chris-in-LA
    Jul 19, 2018
    1,356
    1,099
    I could be wrong but the 1959 might be more suitable for mods due to the construction, especially if it is a turret board. The jcm800 amps all have PCB construction and that makes them harder to mod than if they had a turret board.
    JM5010 likes this.
  11. JM5010
    Nov 11, 2017
    187
    26
    That could be it. Either way, the mod is commonly done on 90's 1959SLP reissues, which have PCB construction.
  12. Chris-in-LA
    Jul 19, 2018
    1,356
    1,099
    Right, not saying it can’t be done, just might be a little more involved.
