1959hw Question - Revisions?
Discussion in 'Marshall Amps' started by cooljuk, Apr 1, 2019.
  1. ampmadscientist
    17,860
    12,087
    One of the few significant changes I noticed was: addition of hum balance pot.
    This may or may not be inside your HW....but I think probably it is.
    cooljuk likes this.
  2. cooljuk
    cooljuk Active Member
    Mar 11, 2009
    304
    90
    Interesting. Though I may not mod it, at least for a while, I'll definitely take the chassis out and get some gut shots for record of the circuit, etc. I'll probably re-tube and bias it, anyway.
  3. lespaul6
    lespaul6 Active Member
    Dec 13, 2007
    141
    173
    Florida
    congrats OP.. its a great amp. And there isnt a thing wrong with those dagnall transformers. No one who is criticizing them actually knows what in hell they are talking about e.g. is it the steel used? if so, prove inferior steel? is it the winding method? prove specifically what is lacking? is it the insulation material? please provide evidence how this is sub par... they cant. Most important is the primary impedance- paper vs plastic is nonsense. Enjoy your amp!
    Mitchell Pearrow and cooljuk like this.
  4. ampmadscientist
    17,860
    12,087
    If there is a hum balance pot in your amp, it's probably better to remove it and replace it with resistors.
    The hum balance pot explodes.
    When this happens, you will hear a lot of loud humming. (now you know why)
    The hum balance pot is replaced with 2X 100 ohm 1/2 watt resistors. This (so far) has solved the problems.
    No I wasn't kidding. The hum balance pot really does explode. I have seen this happen at least 4 times in 4 amps.
  5. cooljuk
    Mar 11, 2009
    304
    90
    That looks like a 1987x.
    You're saying the 1959HW can have a similar pot?
  6. Yamariv
    Yamariv Well-Known Member
    Mar 19, 2017
    544
    314
    Ottawa, Canada
    Congrats James! Remember, Pics or it didn't happen though.. :fingersx:
    cooljuk likes this.
  7. cooljuk
    Mar 11, 2009
    304
    90
    I was just waiting for a time to be available with it during daylight. :D
    I'll get some today, including gut shots.
    Mitchell Pearrow and Yamariv like this.
  8. cooljuk
    Mar 11, 2009
    304
    90
    Opened it up to check and adjust the bias, today. I was sure to get some glorious gut shots...
    Mitchell Pearrow and K2JLX like this.
  9. K2JLX
    K2JLX Well-Known Member Gold Supporting Member
    Apr 20, 2018
    393
    813
    The colonies
    Gorgeous amp, and nice shooter on the bench, holstered.
    cooljuk likes this.
  10. Yamariv
    Mar 19, 2017
    544
    314
    Ottawa, Canada
    Wow, she looks minty! Nice score James!
    cooljuk likes this.
  11. cooljuk
    Mar 11, 2009
    304
    90
    Do you guys know if anyone has done a comparison demo of the 4 Ohm / 16 Ohm outputs through the same four speakers? ....because of the variable negative feedback in this circuit being tied to the impedance selector switch, I mean. I've messed with negative feedback on amps before but, at least to me, each type of amp seems to respond differently to changing it.
  12. cooljuk
    Mar 11, 2009
    304
    90
    btw -
    In a strange turn of events, that seemed extremely shady at first but ended up working out, I got an extra set of Chinese G12M 75Hz speakers with that cab, in addition to the factory UK G12H 55Hz set.
    The Chinese ones don't sound awful. :shock:
  13. OdgeUK
    OdgeUK Member
    Sep 9, 2010
    94
    17
    Worthing, UK
    1959HW looks like it using a split cathode setup, not shared.
  14. cooljuk
    Mar 11, 2009
    304
    90
    It is. You can see the extra resistor cap on the input side of the board. At least mine is and so is the 1959HW schematic Marshall put out.
  15. cooljuk
    Mar 11, 2009
    304
    90
    A two year old bump to remind me that, at one point, that in-house workbench was actually CLEAN!
    I can hardly turn around in that room, now.
    Chris-in-LA and twangsta like this.
