1202-84 OT on JTM100 Super PA - EL34 or KT66
Discussion in 'Let's Talk Vintage' started by VanillaGorilla, Sep 26, 2021.
  1. VanillaGorilla
    VanillaGorilla Member
    Sep 27, 2014
    83
    40
    A friend of mine is selling his 66-ish Super PA 100W JTM, right now it is equipped with EL34s, it has the 1202-84OT. Did it come stock with EL34 or was it a KT66 Amp from the factory?
    Thank you, Ben
  2. Seanxk
    Seanxk Well-Known Member
    May 14, 2018
    880
    784
    As far as I know the 1202-84 was for use with KT66 and had an primary impedance of 4K, I'm not entirely sure but someone will be along soon hopefully. Let's hope it hasn't done any damage.
    VanillaGorilla likes this.
  3. neikeel
    6,624
    5,682
    In my experience it should be running KT66s as it has z of 4k which matches the 8k that a two cylinder JTM45 runs. An EL34 amp for 4 tubes @ 100w be 1.7-2k primary impedance. You can run EL34s but they will not give you full power - you would need to run a half step mismatch on your load for that ie use 16ohm selector for 8ohm load.
