Michael Inglis
- Joined
- Feb 7, 2018
- Messages
- 198
- Reaction score
- 119
Just installed a Choke in my DSL100HR, sounds great so far. Low end is certainly tighter than before when the volume is up to gig levels. Pics at bottom for the hell of it.
But the point of this post is to pose this question. I want to add a switch on the chassis so that i can switch between the 220 ohm resistor and the choke (when the amp is turned off obviously, ill have to take the back off the amp to switch it and if someone else ends up with the amp they would have to also. That should insure its not switched when the amp is on, ill even used a vinyl decal to warn against doing so). Ive seen other guys ask this question and the answer has always been "sure it will work but youll have to find an adequate switch which might be hard"....hmmm, a 100 watt tube amp would roughly draw .83 amps (100watts divided by 120v). And every dpdt switch ive used in my pedal builds has a rating of 2A @ 250V and 5A @ 120. So....what gives? That seemed pretty easy to find to me.
The mains fuse on my DSL100 says its 4 amps so even if the amp magically was able to draw that much current the fuse would go before the switch would if the rating on the switch is to be trusted, correct? Or am i missing something?
It should be mentioned i plan on using a slightly better quality switch just in case but the question remains, if those ratings are to be believed wouldn't those little red DPDT switches suffice?
