SilkWilk
- Joined
- Oct 1, 2019
- Messages
- 53
- Reaction score
- 19
I’ll be honest guys so far my readings on OT are fairly consistent. I’m measuring from the b+ tap where the OT primary comes in and connects to the the first mains cap. Then I’m measuring at the output tube sockets and getting consistent resistance across all of them. Later tonight I will post my readings.
I was considering impedance selector as well seemed like a reasonable thought. The wires are all solid but I’ll have to check resistance there as I have not.
I did try both output jacks to no avail. I still need to try a new preamp tube I did switch them around with no change but my thoughts are an open preamp tube is an open circuit no matter where you put it the signal is dropping. I’m still hopeful that’s all it is but won’t be able to grab a new tube until tomorrow. I’ll recheck OT tonight as well as the output section.
I did change from a variable feedback - to the 4 ohm tap (100k nfb) a couple years ago but it never caused any issues.
I typically run the amp on 16 ohms to a 16 ohm 1960a 4x12
