Matthews Guitars
- Joined
- Aug 17, 2019
- Messages
- 6,154
- Reaction score
- 9,764
I've noticed, as I was browsing the Amp Archives, that despite the fact that Marshall's schematics always show a '59 as having four 5.6K grid stoppers, Marshall apparently incorrectly installed just TWO in, basically, every original pre-1970 amp I saw photos of.
Starting in 1970 they put the grid stopper resistors on the tube sockets and linked them up
with short wire links for each outer pair. That matches the schematics.
But before that, they way they had it, only the outer two tubes actually got the benefit of the grid stoppers. The inner pair were direct connected. The outer pair were connected thru a 5.6K resistor via its uncut leads.
What's the deal on that? Was that actually a commonly repeated assembly error or did engineering tell them to "do it this way, not what's on the schematic"?
And how does that change materially affect the amp?
It seems to me that since this is on the audio input signal to the power tubes, the inner two tubes get a slighly hotter signal, with a higher chance of achieving blocking distortion in those two tubes as well.
