Zakk Wylde Overdrive
Discussion in 'The Tone Zone' started by EddievanDamon#2, Feb 1, 2019.
  1. EddievanDamon#2
    EddievanDamon#2 Active Member
    Mar 19, 2018
    80
    123
    Hey guys! What are your thoughts on this pedal? I am looking to push the front of my jcm 800 2203 and thought i'd try this pedal. Anybody here ever use one?
  2. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    8,248
    5,131
    I had the older one, works great.
    The new one is called "the Bezerker" but basically should be the same circuit.t
  3. thunderstruck507
    thunderstruck507 Well-Known Member
    Apr 20, 2017
    314
    353
    You can save yourself some coin if you don't get the one with the bullseye on it.
    MXR Classic Overdrive is the exact same pedal but with a dip switch in a different position inside the case. You can score those pedals for $30 used at Guitar Center online frequently.
    The dip switch just requires pulling the back cover, taking off the knobs, and pulling the board. You can even drill a hole in the face of the pedal then switch between modes without taking it apart every time.
    Zakk Wylde mode keeps more lows, Classic mode sounds more Tubescreamer.
    I used this pedal to push my TSL and it was great, volume max and gain at 0-1, tone to taste. I wish I hadn't sold it now that I have the JCM 800.
  4. Wooferhead1
    Wooferhead1 Well-Known Member
    Jan 19, 2019
    567
    962
    Ohio
    Thanks Thunder I've got the Zak bullseye model gonna check out the dip switch today:hmm:
  5. Wooferhead1
    Jan 19, 2019
    567
    962
    Ohio
    I run mine into my VM to get a thicker rhythm/lead with a Strat or LP 11 o'clock on the tone & gain - using guitar volume knob to roll back the drive for rhythm.
  6. Wooferhead1
    Jan 19, 2019
    567
    962
    Ohio
    No dip switch on mine?? Must be a slightly different design...
  7. thunderstruck507
    Apr 20, 2017
    314
    353
    Depends on whether it's the original or the Berzerker or whatever they call the revision.
    Basically MXR had the GT-OD overdrive and the Wylde Overdrive, the switch changes something minor in the circuit. Then they released the MXR Classic Overdrive originally as a Guitar Center black friday deal or something similar which is the same as the above pedals with a different paint job (they come in cream or green).
    That's not to say versions might not exist without the switch but the ones I've opened have all had it.
    Mitchell Pearrow and Wooferhead1 like this.
  8. lespaul339
    lespaul339 Well-Known Member
    Dec 28, 2010
    558
    532
    Iowa
    The true Zakk Wylde tone with a 2203 is to push it with a boss sd-1. When I had my 2203 I could nail his tone with that pedal.
    Delete!! likes this.
  9. thunderstruck507
    Apr 20, 2017
    314
    353
    The Wylde overdrive is a clone of the SD1. There is a video on youtube of a guy comparing the EQ curve of all 3 pedals and they are virtually identical within the spectrum of human hearing.
    Lance Chambers and Delete!! like this.
  10. Delete!!
    Delete!! Well-Known Member
    Jun 29, 2018
    252
    310
    San Joaquin Valley, Ca
    I used to have the first incarnation of this pedal, and while it was perfectly fine I still think the stock $50 Boss SD-1 is hard to beat if you’re just pushing an amp.
    Lance Chambers likes this.
  11. Lance Chambers
    Jun 23, 2019
    1,434
    2,187
    The Land That Time Forgot
    The original MXR "Wylde Overdrive" doesn't have the internal dip switch.
  12. Solid State
    Solid State Well-Known Member
    Jan 2, 2016
    334
    501
    I have the SD-1 and the Wylde OD and while they're not miles apart as far as sound goes, the Wylde OD is definitely a different pedal than the SD-1. The Wylde OD is more balanced and doesn't murk up the mids at higher gain settings. It adds a lot of clarity to the sound above and beyond what an SD-1 is capable of
  13. chromeboy
    chromeboy Well-Known Member
    Jan 25, 2010
    585
    276
    San Bruno,CA
    I've used several overdrive pedals and the od1 was great into my jcm800. Also though a big part of zaks sound is I believe a chorus pedal as well as the the overdrive.
    Musicmaniac likes this.
