You guys like these voltage and bias numbers?
Discussion in 'Marshall Amps' started by Force235, Sep 21, 2019.
  1. Force235
    Force235 Well-Known Member
    Nov 15, 2012
    950
    452
    MA
    I replaced my power tubes yesterday, in my 6100 (EL34) LE. You might have seen my other post where I blew up a tube at practice, tube simply failed (Sino, less than 9 months old with medium usage).
    I ordered Phillips 6CA7s (45 bias point, 24 hr burn in), After some adjustments, I've ended up with
    472v grid voltage
    over 1 ohm resistor
    34.5mv = 16.2 watt
    30.0mv
    30.1mv
    31.7mv = 14.9watt
    Amp sounds great, do you like these numbers for these tubes and amp?
  2. Kinkless Tetrode
    Aug 17, 2017
    848
    963
    The set seems to be well matched.
    I think the bias at about 60% is a lil cold. But if it sounds great to you that is what matters.
  3. South Park
    South Park Active Member
    384
    232
    Check the data sheet for max bias wattage.its the bias amps you are after.70 percent of max is a good start.hope that helps
  4. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    642
    435
    NJ
    yea, 60% is fine if it sounds good to you. also try 37mV (mA) this would be 70%.
    At this point, it's all about your personal preference
  5. Lance Chambers
    Jun 23, 2019
    495
    637
    The Land That Time Forgot
    You can rotate the tubes through each socket and get better matching.
    That's been my experience! :cheers:
    Force235 likes this.
  6. Force235
    Nov 15, 2012
    950
    452
    MA
    Ahh, thanks, good comments and ideas to try.
  7. anitoli
    anitoli Well-Known Member
    6,521
    7,165
    16w is just fine in a 6100.
