Wiring Question
Discussion in 'Cabinets & Speakers' started by rich88uk, Mar 11, 2019.
  1. rich88uk
    rich88uk Well-Known Member
    May 25, 2009
    622
    511
    Liverpool,UK
    This is going to sound really stupid but I need some help.
    I have been thinking about swapping out the top speaker in my mini jubilee angled cab for a greenback of some description and started scouting Ebay to see my options. I have just took the back off to have a look and I thought it would just be a case of unplugging the speaker wires, unscrew it, put the new one in and clip the wires back in. But I cant seem to remove the wire, are they soldered in? I can't quite make it out. I can't solder either which wont help the situation if this is the case:
  2. stringtree
    stringtree Well-Known Member
    May 21, 2016
    533
    835
    Have you tried a very small flat head screw driver, easing it into the clips to open them up...then see if they pull off.
    Don't want to wiggle them free because you could break the dog ears on the speaker..
    I hope I have my guitar speaker jargon right.
    rich88uk likes this.
  3. rich88uk
    May 25, 2009
    622
    511
    Liverpool,UK
    I've not tried that no, I have them a quick tug and when there was no give I stopped, didn't want to balls it up if they were soldered. Never messed with speakers before
    stringtree likes this.
  4. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,399
    4,025
    Lakeland, TN
    Don't look soldered...
    Use two pairs of pliers, one holding the connector and one holding the speaker's connector...pull apart.
  5. rich88uk
    May 25, 2009
    622
    511
    Liverpool,UK
    Ok great, thanks for your help
  6. RobS
    RobS Active Member
    Apr 19, 2009
    865
    119
    Melbourne - Australia
    keep in mind the tab on the speaker has a tiny hole that the connector kinda locks into, this is probably whats making it difficult to separate.
    persist gently and youll get there
    67Mopar and rich88uk like this.
  7. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    WATCH the entire video.
    SKIP to 0:56 in the video to learn HOW to use the screwdriver blade to lift the female connector.
    Angel Acevedo Video Please Watch
  8. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    This is a "Faston" connector. (also called "Quixon," etc...)
    Some Faston connectors will have the locking tab. (look carefully)
    The Faston connectors on speakers may not have this locking feature.
  9. rich88uk
    May 25, 2009
    622
    511
    Liverpool,UK
    This is incredibly helpful. Thank you very much
  10. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    "Use two pairs of pliers, one holding the connector and one holding the speaker's connector...pull apart."
    No, do not do that! It can break the speaker terminals.
    DO NOT try to pull or force the connectors apart with pliers!
    Watch the video and learn the right way to do this.
    Be VERY gentle when you take the Faston connectors apart.
    rick16v and rich88uk like this.
  11. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    663
    756
    I have a set of Heritage G12M's that I'd like to try in my SJ 4x12, but I'm concerned with the db rating difference between the G12M's and the G12T's. The greens would be angled upward, so maybe it's not an issue?
  12. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
  13. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    Are these 4 speakers all 16 ohm speakers?
    If these are all 16 ohm it's probably OK fine to do that.
    Efficiency is another question but it won't hurt anything I don't think it will.
    67Mopar likes this.
  14. 67Mopar
    Jun 14, 2011
    663
    756
    Yes, all of them are 16 Ohm.
  15. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    I think it would work OK.
    67Mopar likes this.
