will a 425A properly fit on top of a 1960B
Discussion in 'Cabinets & Speakers' started by bgtjr, Feb 12, 2020.
  1. bgtjr
    bgtjr New Member
    Jun 12, 2019
    6
    Northern Ohio
    Hello there, I am able to purchase a Modern Vintage 425A cab for a very good price, I am wondering if it will fit properly on the JCM900 B cab, would appreciate any input...Thank you
    netlocal likes this.
  2. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,812
    4,585
    Lakeland, TN
    Yes, no problems. My 425A fits on my JCM800 1960B, just perfectly.
  3. bgtjr
    bgtjr New Member
    Jun 12, 2019
    6
    Northern Ohio
    Thank you Gibson67.....
  4. Seanxk
    Seanxk Active Member
    May 14, 2018
    228
    173
    And those speakers are just superb.
  5. StingRay85
    StingRay85 Active Member
    Aug 18, 2019
    280
    96
    Speakers superb, cab cheap fibre board
  6. Georgiatec
    Apr 23, 2010
    5,290
    4,249
    I have both the 425a & b. Pretty sure they are Marine ply, same as the 1960 a/b. I will check later.
    GIBSON67 likes this.
  7. StingRay85
    Aug 18, 2019
    280
    96
    They're not. At least mine is not
  8. Seanxk
    May 14, 2018
    228
    173
    Have a purple one here, all marine ply, even the backboard.
    Georgiatec and GIBSON67 like this.
  9. GIBSON67
    Sep 8, 2008
    8,812
    4,585
    Lakeland, TN
    Check again, I thought mine was MDF or something but it just looked that way from all the black overspray. They are same construction as 1960 cabs.
  10. StingRay85
    Aug 18, 2019
    280
    96
    Yeah I checked it even before seeing your post. Its indeed covered with some spray which made it look like cheap fibre. My back panel is fibre though
  11. Georgiatec
    Apr 23, 2010
    5,290
    4,249
    The spray is the glue. After assembly they are hooked on an overhead conveyor and into a glue spraying machine. They then go into an oven where they are heated ready for tolex application. The glue becomes active with the heat and the tolex is then applied to the glue.
    This is why the best way to repair a tolex rip is to heat the area with a heat gun then stick the tolex back in place. Don't worry you can't get the area too hot, the oven at the factory is of couple hundred degrees C. If they had it much hotter the cabs would come out the other end on fire lol.
  12. Seanxk
    May 14, 2018
    228
    173
    Guys!, it's only 4 screws!
  13. StingRay85
    Aug 18, 2019
    280
    96
  14. bgtjr
    bgtjr New Member
    Jun 12, 2019
    6
    Northern Ohio
    Thanks everyone, its been awhile since I was involved, wanted to get back in the game, got a JVM410H with the 1960B, but when I put the Modern Vintage in the loop, I now totally remember why Marshall ROCKS, I forgot about how good Feeling the overtones is....my neighbors are concerned....
  15. GIBSON67
    Sep 8, 2008
    8,812
    4,585
    Lakeland, TN
    Square magnet Eminence before or after you hooked them up?
  16. StingRay85
    Aug 18, 2019
    280
    96
    I'm still in the process of hooking them up LOL, too many stuff to do so little time. They came out of Acoustic Control Corp combos. Interested? ;-)
