Who Regulates Voltage
Discussion in 'Let's Talk Vintage' started by emitch.sr, Feb 1, 2018.
  1. emitch.sr
    emitch.sr Member
    May 13, 2010
    105
    5
    How many of you guys here use something to get your voltage down to the 110 territory for these old amps
    If so what is your preferred method
  2. Crunchifyable
    Crunchifyable Well-Known Member
    Oct 28, 2011
    662
    339
    Georgialina, USA
    I don't own one of these...but if I had vintage amps, and didn't have a "bench power" type set up (aka variac or buck / boost transformer) I'd have something like this
    Kind of expensive for what it is ($250)...but probably worth it on vintage gear.
    emitch.sr likes this.
  3. Humbucking
    Humbucking New Member
    Jan 11, 2016
    2
    I use a variac to feed my amps between 108-112v. I also put a digital meter inline with my variac so I always now what it is putting out.
    liontato likes this.
  4. ampmadscientist
    13,434
    7,290
    Variac...
    The output of a SS regulator is not going to be a clean AC sine wave.
  5. mickeydg5
    22,109
    9,589
    What amplifier do you have that requires 110VAC?
  6. houseofrock
    houseofrock Well-Known Member
    Jul 10, 2015
    674
    637
    Florida
    If the bias is set correctly, is it necessary to step down the voltage to 110 from 120/125ish?
    I believe my wall voltage is at 124 and my '79 2204 has been biased accordingly by my tech (64%).
  7. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,453
    1,449
    It is interesting two put an amp in front of a variac and listen to how the sound changes with a couple of voltage up or down. It is not super dramatic but their is a change in tone, nothing to worry about playing live on various pubs and clubs as in a band situation the drummer and bass kills your tone anyway!
    But since we here feel as if we can hear differences when changing the value of a single cap inside the amp only slightly
    A variac changes your tone more
    Plexi
  8. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,622
    2,539
    Ide be worried my amp would blow up the whole time i was playing it.
  9. liontato
    liontato Well-Known Member
    Sep 24, 2012
    690
    548
    A variac at 110 (with bias) will have a different feel and sound. You’re running lower voltage throughout the entire amp. Considering the PT ramps up the voltage quite a bit it’s a significant difference. You can run 125 if biased properly. No question it’s a little more wear in the amp.
  10. emitch.sr
    emitch.sr Member
    May 13, 2010
    105
    5
    My 2203 from 1980 has a sticker on back that has model number and power ratings and such
    And a 110/240v~ Place on that sticker from factory.
    My 74 superbass does not have anything to indicate the voltage.
    This amp will be going to a tech soon so I will be finding out what voltage it wants.
    They both have stickers from techs that indicate mA.
    The 2203 says 27mA idle current.
    The super bass says 55mA cathode current.
  11. emitch.sr
    emitch.sr Member
    May 13, 2010
    105
    5
    What got me thinking about this in the 1st place is a video with jd simo running a variac to allow his amp to maintain proper voltage.
    So I’ve been doing research and finding different ideas about proper voltage.
    I like the brown box that crunchifyable posted a video of but I am in the dilemma of not enough cash to get one and get my superbass taken to a tech for new tubes and whatever else it will need.
    I am leaning towards variac $50-$60
    The voltage from my wall at my house has ranged from 117 to 124 at various times
    So that makes me wonder if I should also run a conditioner and a variac
  12. liontato
    Sep 24, 2012
    690
    548
    I like 110. Softer overall feel. More sag. Not as stiff. Less bass. More vintage sounding. Slightly lower in volume. I use a multi meter and get it exact when I use that option.
  13. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    969
    499
    The way to tell what voltage your amp wants (was made for) is to plug the amp into a variac and take the filament voltage reading (pins 2 & 7 on octal power tubes). Adjust variac to read 6.3 - 6.4 volts for the filaments. When I do this and then take a reading of the input voltage to the amp, it's always somewhere between 110 - 115 volts in.
  14. coldengray
    coldengray Active Member VIP Member
    May 19, 2011
    408
    187
    I've measured my amp (the method danfrank mentioned above) and it "wants" to see 108.9v so I set my variac to where it's jumping between 108 and 109. My variac was about $120 I believe...nothing fancy.
    Don't run a vintage amp at modern voltages!
  15. danfrank
    Mar 5, 2015
    969
    499
    By chance did you measure the B+ voltage of the amp while your variac was set to 108 volts?
    What amp is it?
    I have a friend that has a Sovtek MIG50 that has B+ voltages of 550-560 volts and filament voltages of 7.2 volts when the amp is plugged directly into the wall (USA 122 volts). The amp says "110 or 220 volts in". When I lowered the input voltage with a variac to 110 volts, the filament voltage was right at 6.4 volts and the B+ voltage was right at 495 volts, which are more reasonable numbers...
  16. emitch.sr
    emitch.sr Member
    May 13, 2010
    105
    5
    Checked the wall voltage today and it was 108-113 I had a quartz heater plugged in the same room
    When I unplugged the heater voltage went back up to around 120
    The amps did seem to be in a sweet spot with lower voltage
    I would have thought the heater would have added noise but it didn’t seem too add any
    Crunchifyable likes this.
  17. danfrank
    Mar 5, 2015
    969
    499
    The heater is just a big resistor that gets red hot
  18. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    8,248
    5,113
    NO ...
  19. coldengray
    May 19, 2011
    408
    187
    ‘65 JTM45
    B+ was 425 I believe.
  20. Crunchifyable
    Oct 28, 2011
    662
    339
    Georgialina, USA
    I was going to say..the same thing happened to me this year. Kid in the next room was using a space heater and the voltage dropped by about 8 volts. Enough to make modern amps sound better.
    But also enough to make me not want to use my "high tech" auto biasing amps under such changing voltages.
    It makes me want to make a simple buck converter to drop the wall voltage from 123 to ~115 to make everything sweeter.
