Which pickup is this ? Hows your telepathy ?
Discussion in 'The Tone Zone' started by Australian, Dec 11, 2019.
  1. Australian
    Australian Green Beret VIP Member
    Apr 20, 2009
    17,411
    9,513
    I never did bother to find out what pick-up this guitar had in the bridge. I bought this guitar on Ebay about 15 years ago. I just know I love the tone, it does AC/DC well.
    It's time to end the mystery. I'm halfway through taking the pick guard off so any guesses?
  2. South Park
    1,266
    946
    S m Duncan super distortion
    Mitchell Pearrow and Australian like this.
  3. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,729
    4,472
    Lakeland, TN
    I am going to guess...Gibson 490T.
  4. Australian
    Apr 20, 2009
    17,411
    9,513
    I thought it was going to be a Seymour or Dimarzio, but ? :
    Neck PU:
    Bridge PU:
    Mitchell Pearrow and GIBSON67 like this.
  5. GIBSON67
    Sep 8, 2008
    8,729
    4,472
    Lakeland, TN
    I like my 490T and it definitely gives up that AC/DC tone. But check the impedance to see which model it is...
    Australian and Mitchell Pearrow like this.
  6. pedecamp
    13,651
    9,959
    Unfortunately without a sticker on it you will never know what it really is, you can only guess based on how it measures on a meter. :(
  7. bad565ss
    bad565ss Well-Known Member
    Apr 5, 2015
    331
    524
    Waterford, Michigan, USA
    Dirty Finger?
  8. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,301
    1,264
    Unless it's DF or 500t, I'm disgusted and horrified
  9. AlvisX
    AlvisX Well-Known Member
    May 31, 2011
    4,074
    7,291
    I-55 Corridor
    Not a dirty fingers ...DF's have two rows of screw poles , no slugs
    Probably a 490 ....which can be a great bridge pickup in the 8.5k range
  10. Australian
    Apr 20, 2009
    17,411
    9,513
    Yeah 490T seems right. I didn't measure the impedance but will in the future.
    GIBSON67 likes this.
  11. pedecamp
    13,651
    9,959
    What tonality does it have? Could be 490, 57, 57+, 498, 500, 496, BB, BB Pro, measure it to help narrow it down. :yesway:
  12. Australian
    Apr 20, 2009
    17,411
    9,513
    It has a vintage tone . Perfect mids, well balanced. Not real hot but somewhat hot.
    what do you get from that description?
  13. ampmadscientist
    14,970
    8,800
    Looks like the stock Gibson SG pickup.
    A pretty good pickup I think.
  14. pedecamp
    13,651
    9,959
    What do you mean by perfect mids? I'd like to know what it measures on a meter, plug a guitar cable into the guitar and take a measurement from the other end of the cable.
    Sustainium likes this.
  15. Australian
    Apr 20, 2009
    17,411
    9,513
    Measured with a patch cable plugged into the guitar:
    bridge PU
    13.86
    neck PU
    13.17
  16. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,591
    1,677
    Södertälje, Sweden
    Sounds like 498. Excellent rock pickup. 490 would be around 8k5
    The vintage(styled ) pups from Gibson don't have the bottom plate stamped like that.
    Notice the holes in the bottom plate. Is made for use with either neck or bridge spacing poles/ screws. . Both your pickups look like bridge spacing which correlates to them both being 490T or in this case more likely 489 suggested by the resistance reading
    J
    Australian likes this.
  17. Australian
    Apr 20, 2009
    17,411
    9,513
    So you think they're both 598T's-both Bridge pu's ?
    The neck pickup needs to be changed- Its too loud even though I have lowered it right down. And its sort of muddy as a neck pu.
  18. johan.b
    Feb 21, 2015
    1,591
    1,677
    Södertälje, Sweden
    look at the pole spacing. that and the 13k suggest 498...but I guess it could be something else but thats what I think
  19. johan.b
    Feb 21, 2015
    1,591
    1,677
    Södertälje, Sweden
    On Gibson pickups built for neck position the screws would go into the narrower holes and slugs on the wider hole side. Both your look like the go into wider holes. (Compare to the bobbin screws that sits in the same position either way)
    J
  20. Adieu
    Jan 12, 2013
    1,301
    1,264
    They're two bridge pickups aren't they?
    Possibly same model, just cover on / cover off, and the usual +/- 5% winding accuracy. Or even just old pots that don't go quite all the way to wide-open, no-addl-resistance
