Which kit to start with?
Discussion in 'Building the Classics' started by jchrisf, Dec 16, 2019.
  1. jchrisf
    jchrisf Well-Known Member
    Feb 27, 2016
    420
    337
    I've been studying and learning about modding/building amps. I think building a kit with good instructions would be a wise thing to do now. It seems from everything I have researched that the 5F1 kit would be the best amp to start with but before I order one.. I'm not really a Fender amp guy. Is there something similar (easiest to build, low part count and has good instructions available) with more of a Marshall tone? Or can the 5F1 be modified to sound more Marshall-ish?
    What do you pros suggest for my first build?
  2. South Park
    1,186
    892
    High octane tube amp is a good first build. Single ended high gain.el84 driver
    ibmorjamn and jchrisf like this.
  3. ampmadscientist
    14,811
    8,664
    https://el34world.com/schematics.htm#Hoffman_5F1_Tweed_Champ
    https://hoffmanamps.com/MyStore/per...r&thispage=Amp_5F1Parts.htm&ORDER_ID=!ORDERID!
    https://www.mojotone.com/kits/TweedAmpKits_x/Test-Tweed-Champ-Amp-Kit
    jchrisf likes this.
  4. anitoli
    anitoli Well-Known Member
    7,003
    8,009
  5. ampmadscientist
    14,811
    8,664
    The larger amps based on Marshall are more complicated.
    Maybe you want to start with a Fender kit and try not to do everything on the first build, but rather learn some basic assembly and soldering skills.
  6. Ken Underwood
    Oct 16, 2013
    373
    1,029
    Can you use a soldering iron.
    jchrisf likes this.
  7. ampmadscientist
    14,811
    8,664
    Exactly.
    But a journey of 1000 miles begins with one single step.
    I hope he does learn it, and I hope he doesn't give up.
    ricksdisconnected and jchrisf like this.
  8. anitoli
    7,003
    8,009
    If he's building a kit based on a turret board he shouldn't have too much trouble provided he doesn't attempt this with a shitty soldering pencil.
    jchrisf likes this.
  9. jchrisf
    Feb 27, 2016
    420
    337
    I just found this today right after I posted here. Have you built it? These amps sound pretty good but I couldn't figure out where to buy the kit. How much is it?
  10. jchrisf
    Feb 27, 2016
    420
    337
    Yeah, I'd like to start with something simple first to figure things out a little more and then maybe a Ceriatone 2202 kit.
  11. jchrisf
    Feb 27, 2016
    420
    337
    I took an electronics class in college and loved it. Did a lot of soldering there and was pretty good but it has been awhile. I've also soldered guitar electronics.
  12. jchrisf
    Feb 27, 2016
    420
    337
    Thinking about getting a Hakko adjustable solder gun.
  13. jchrisf
    Feb 27, 2016
    420
    337
    ricksdisconnected likes this.
  14. anitoli
    7,003
    8,009
  15. ricksdisconnected
    Aug 11, 2019
    980
    1,529
    jchrisf likes this.
  16. anitoli
    7,003
    8,009
    Variable temp and the ability to use different tips.
  17. Madfinger
    Madfinger Well-Known Member
    Feb 16, 2019
    282
    421
    Straya
    I've been thinking of building one myself. Checking out the Mojotone kits the 5E3 Delux doesn't look much more complicated than the 5F1 Camp and you can get the turret boards assembled if you want.
    The Rob Robinette web site https://robrobinette.com/Amp_Stuff.htm provides a lot of mods for 5E3 circuits & others if you want to check it out he seems to be all over amp builds & mods.
    Prob. order one once I find a cheap 1×12 or 2x10 birch or pine amp that will suit so I can gut the chassis.
    Metroman, ibmorjamn and jchrisf like this.
  18. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    1,851
    1,298
    Las Vegas, NV
    Nobody's mentioned it, but many/most of the Tweeds sound more "Marshall-ish" than sounding like the later (Black/Silver Face) Fenders. The farther you get into them you start to realize that much of the difference from one model to the next is caused by different versions of negative feedback/presence circuits and the use of various "local" feedback layouts. For example, compare the schematics of the 5E7 Bandmaster, 5F4 Super and 5E5-A Pro. They're identical except for a couple resistors. Make sure you pay attention to the letter after the dash, as it can make a HUGE difference as in the 5E5 & the 5E5-A. Some differences are small/subtle and others, not so much! Here's a link to most of the earlier Fender schematics and layouts for your perusal:
    https://vintagefenderamprepair.com/pages/library-schematics-layouts
    And FWIW, it's very cool that you want to get your feet wet in amp building. It's a "VERY" addictive passtime that is easy to become extremely passionate about! Its fun to ponder building an amp configuration that's never been m"offically/commercially" done. For example, I've determined that I really like thekinda ragged, slightly imblanced cathodyne phase inverter and cathode biased 6V6 power amp of the 5E3 Deluxe, but may prefer a more elaborate preamp of a Pro, BandMaster or Twin, but don't want to lose the magic of the Deluxe, but want to simply "add" to it!
    Do yourself the great service of lots of research before diving in.
    Have Fun<Be Safe!
    Gene
    Madfinger and jchrisf like this.
  19. Im247frogs
    Im247frogs Well-Known Member
    Jan 31, 2012
    351
    398
    Brooklyn, Joey!
    I like the way it has password protection to deter unauthorized soldering.
    jchrisf likes this.
  20. jchrisf
    Feb 27, 2016
    420
    337
