Where in my chain to put boost pedal
Discussion in 'The Tone Zone' started by Shane Stevenson, Mar 14, 2020.
  1. Shane Stevenson
    Shane Stevenson Well-Known Member
    Oct 17, 2019
    235
    641
    I’m thinking about buying a Spark Boost Mini. At the moment my pedal board is minimal and thats how I like it with my SV20h. In this order here is what I have going on: guitar, tuner, tubescreamer mini, ts808, and Keeley reverb/delay at the end. My keeley is going into my effects loop so I’m running 4CM.
    Should a boost pedal go in between my ts808 and my reverb/delay pedal and should I run a boost into the effects loop?
    tce63 likes this.
  2. South Park
    2,211
    1,798
    is Thar a reason you need a boost pedal
    tce63 and Sustainium like this.
  3. ricksdisconnected
    Aug 11, 2019
    3,200
    4,264
    well you can put it in front of your OD too and you will be boosting just the pick up signal alone then into your OD.
    run boost just before or just after od. ymmv
  4. AlanH
    AlanH Well-Known Member
    Jul 2, 2017
    532
    587
    UK
    For volume boosts in the loop, before modulations and delays.
    For extra compression, before whatever you're goosing (TS mini, 808 or front end preamp section of amp)
    tce63 and Bull Rock like this.
  5. ampmadscientist
    17,983
    12,012
    I think the boost should be the last pedal in the effects loop, then into the effects return.
    This way the power amp can be pushed as far as it will go. (if it can be pushed any further than it already is)
    But people with noisy pedals and noise gates are going to cry cry cry.
    I'm going to use a pedal in the loop that doesn't need a noise gate to start with, maybe that sounds crazy.
    tce63 and El Gringo like this.
  6. scozz
    scozz Well-Known Member
    Jul 20, 2008
    3,248
    7,364
    I run my Spark boost in front of my SC20, right after my Maxon OD9. I also use the 4CM, I have my Delay, Chorus, and EQ pedals in the loop.
    This works for me.
  7. Bull Rock
    Bull Rock Well-Known Member
    Aug 27, 2015
    1,665
    2,373
    Canada Eh
    Loop.
    tce63 likes this.
  8. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    888
    810
    incarcerated
    99% of the time a boost/preamp will sound best going through the front, but there are no rules with individual setups as it almost always does not apply to other individuals and their gear.
    A boost could be useful in the loop as an enhancer, combined with a modulation pedal or other effect pedal to thicken the pedals affect, or to alter it for different sounds. Or as a tone shaper.
    *As in Plexi's, SV20's dual channel is useful and offers another possible setup in this situation. Guitar plugged straight into High Treble input 1, then jumpered out from High Treble input 2 into your boost pedal,
    which goes back out into Normal 1 input, now controlling the entire effect's 'blend' with Normal's Loudness knob.
    Several possible configs can be had for these types of Marshall's opposed to other Marshall amps or other amps. YMMV
    tce63, Sustainium and scozz like this.
  9. Kutt
    Kutt Well-Known Member
    May 27, 2010
    1,104
    1,524
    Massachusetts, USA
    Boosts are a "utility" pedal and can really go anywhere. It depends on what you're trying to achieve. I use a boost to goose my signal chain so I have it at the end of my pedalboard, right before it feeds the front end of the amp.
    In the end you need to experiment yourself and test it in all configurations.
    tce63, MonstersOfTheMidway and scozz like this.
  10. Wenander
    Wenander Active Member
    Aug 10, 2015
    227
    244
    Sweden
    put it after the tuner, then experiment with the other pedals wich order is best..some like a kick in the ass some does not. move delay/reverb to the loop
    tce63 likes this.
  11. HOT TUBES 70
    Oct 13, 2008
    11,215
    5,704
    If your looking for all out volume boost , end of the chain in your loop .
    tce63 likes this.
  12. Martin Adams
    Martin Adams Member
    Apr 25, 2019
    20
    31
    I run my spark boost mini in the fx loop for vol boost and have it as my last pedal after delay. Have tried it before delay and that worked ok too.
    Mine is set at 9 o clock for a decent lift
    tce63 likes this.
  13. Sustainium
    Sustainium Well-Known Member
    Oct 4, 2019
    604
    1,210
    Great info, this is the kind of post that keeps me logging on.
    tce63 likes this.
  14. tce63
    Aug 6, 2018
    1,541
    4,003
    Sweden
    I have the 4 knobs version of the Spark Boost pedal, actually I have 2, one i clean mode and one in Fat mode.
    I run them in front of my SV20H, I also have a HOF in the loop, all pedals I need :)
    SkyMonkey likes this.
  15. marco_giampa23
    marco_giampa23 Active Member
    Feb 11, 2020
    247
    222
    STRAYA
    First find out what you would like to do.
    Boost the pre amp? Put it at the and of your pedals
    Boost the power amp? in the effects loop (also works for volume boost)
    Boost another pedal? Puy it infront of said pedal
    hope this helps, just try everything and see what you like
    tce63 likes this.
  16. pedecamp
    14,515
    11,448
    Depends on what youre using it for, you want to add gain to your signal put it out front anywhere, you want to add volume put it at the end of your loop chain. :yesway:
    tce63 likes this.
  17. Marshall4Metal
    Marshall4Metal Well-Known Member
    Jul 28, 2016
    327
    372
    I run my JCM same way this guy does . An overdrive on all the time a chorus I run out front along with my gate so it's chorus overdrive Gate. Then an EQ in the loop to boost that's it .
    His delay is set just to give some space around the notes. I have a delay but I'm not 100 percnt happy with it so i'm not using it if I do it's set basically the same way just enough to give the notes some air and space.
