What To Build . Plexi With One Wire Mod Or Jcm800
Discussion in 'Building the Classics' started by Copperheadroads, Jan 18, 2017.
  1. Copperheadroads
    Copperheadroads Active Member
    Oct 6, 2012
    112
    27
    On a Rock in the North Atlantic
    I`m wanting to build another amp .
    50 watt Marshall with a Lar mar or Ken fisher style PPIMV .
    I`m not sure what would be better , I assuming the plexi would be more versatile ,would adding the one wire mod (cascading the gain stages ) make this amp compete with the jcm
  2. Kris Ford
    Kris Ford Well-Known Member
    Jan 3, 2015
    1,050
    744
    Detroit FTW
  3. stickyfinger
    stickyfinger Active Member
    Nov 11, 2010
    464
    142
    Do the RR OWM and the amp becomes a Bright channel plexi and the normal inputs become a hot rodded gain machine.
    Kris Ford likes this.
  4. Kris Ford
    Jan 3, 2015
    1,050
    744
    Detroit FTW
    Which is just like mine!:hbang:
  5. neikeel
    2,820
    1,308
    You can make it switchable too, then tune the cap/resistor values to your taste, if you like lots of gain.
    Personally I lke the definition and tone of a very slightly warmed up 2204 so have a 2 in 1 plexi/2204 that I use for gigging. It has 8k2 on second stage cathode, 0.68uF/2k7 on first stage (ie stock 2204) and another 0.68uF over 820R on V2a, I like reasonably tight NFB (47k/8ohm).
    soundboy57 and Copperheadroads like this.
  6. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    The one wire mod is Mickey Mouse. (it's a joke)
    Use the 800 2203 schematic.
    http://www.drtube.com/schematics/marshall/2203u.gif
    The plexi has a problem...won't work right until the volume is pegged, producing output tube distortion.. Making the amp waaaaaaay too loud for most applications!
    The plexi is a CLEAN amp which has no distortion until the output tubes overdrive. Face reality.
    The 2203 adds one gain stage...to the plexi design...(it's the same amp w/ one extra stage).
    This allows preamp distortion, to get a better sound at a low volume.
    Plug into LOW input: you have a plexi (basically).
    Plug into HIGH input: you have the extra stage.
    The 2203 is much more practical versatile for lower volume (or all) applications.
    Most people who "want" a plexi...don't really want a plexi....because they do not understand all of the above information....which is very important.
    Add a master volume to the Plexi: It's a waste, it will never give you what you wanted or expected.
    Add a master volume to the 2203: NOW you are talk'in.
    And while I am on the subject of ppimv Master Volume: direct coupled (without capacitors) is way more accurate, and works much better.
    Use a 1M audio pot, which has an insulation rating of 300-500 Volts. (there is bias voltage on the pot)
    Recommended: PEC 1 Meg Pot, which has high voltage insulation.
    https://www.tubesandmore.com/products/potentiometer-precision-electronics-audio-slotted-shaft
    As long as the pot has high voltage rating, there will be no problem whatsoever.
    So...don't use a cheap pot to do this master volume.
  7. m1989jmp
    m1989jmp Active Member
    Apr 24, 2014
    878
    142
    Plexi (1987/1959) with one wire mod IS JCM800 with different resistors/caps on V1b and actually has more gain. Oh and a pre-ppi master volume
    So basically what you're saying is that a plexi with OWM is a clean sounding amp? :)
  8. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    No I did not say that.
    Plexi is a clean amp....(copy of Fender bassman). Until you drive it into maximum, the plexi remains clean. All the way to 100W...
    After you reach 100W, then it distorts, and is extremely loud.
    The one wire mod is a (mickey mouse) attempt to change a Plexi into a 2203.
    Might as well do it the right way...you have the schematic for 2203.
    Plexi = 10mv sensitivity
    V1 One preamp stage > V2 compression Stage > Tone Stack > Phase Inverter> PPIMV> PAmp
    2203 = 5mv Sensitivity
    V1A preamp Stage 1 >V1B preamp stage 2 >V2 Compression Stage > Tone Stack > Phase Inverter >PPIMV >Power Amp
    What you really want is the 5mv sensitivity.
    Your Crunch-crazed brain is actually craving the 5mv, that's what the one wire mod does.
    It's just that building it as 2203 does the same thing, just the "right"way; the factory way.
  9. stickyfinger
    Nov 11, 2010
    464
    142
    Can you explain what you mean by 5mv sensitivity and 10mv sensitivity please? And why that matters?
    I disagree about the one wire mod being a joke as long as there's a master vol after the tone stack or PPIMV. The RR OWM is great as you can still have the Plexi for the gig (or when ever) and when you want great tone to practice, the OWM works great.
    The 2203 low input is no plexi either! That stage produces almost no gain. A PPIMV actually works quite well on a plexi because the output section doesn't distort as much as a Metal panel. The tone is more constant on the Plexis I find.
  10. neikeel
    2,820
    1,308
    A very didactic response.
    Also making the erroneous point that lo input is same as plexi is totally untrue - have you ever tried it?
    I agree if you want distortion then you have two choices, drive the cascaded pre-amp for some distortion and thus push the PI and thence the output stage depending on the pre-PI MV or push the power stage by cranking an uncascaded preamp.
    But, as has been admitted, a pushed output stage sounds best, even with a 2203/4 preamp.
    I like nuance and subtlety as well as distortion hence my assertion that in one amp a switchable hybrid of NMV and MV is an excellent option. The 1 wire mod is just another iteration of a cascaded preamp and it does need a master volume. Choose pre or post PPIMV to taste.
    solarburnDSL50 and Kris Ford like this.
  11. Copperheadroads
    Oct 6, 2012
    112
    27
    I have the Ken fisher type PPIMV on both of my Traynor YBA-1's that are modded to marshall plexi & jcm circuits & it totally makes them very usable . lovey tone
  12. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    5mv VS 10 mv sensitivity, why it matters:
    You keep calling the amp (or the tube) "high gain," but that's not it.
    The amps have the same gain.
    The sensitivity is different - that's what really matters. (people are always confusing "gain" with sensitivity)
    The Plexi has 1 preamp stage - it takes 10mv input signal (from the factory) to drive the amp to full 100W output.
    The 2203 has 2 preamp stages in series, (sometimes called "cascade") it takes 5mv input signal to drive the amp to full 100W output.
    The 2203 is twice as sensitive as the plexi. This is what you really want.
    (this is why you do the "one wire" mod. --- It's increasing the sensitivity!)
    (this is why you use distortion pedals, it's increasing the sensitivity)
    How much input signal does it take to drive the amp to full output?
    That's the sensitivity!
    Guitar player does not realize that this is the most important of all: the sensitivity.
    Second most important: what frequencies compress?
    High frequencies compress: this is what makes amp "Crunch."
    Low frequencies compress: this is what makes amp sound "muddy."
  13. solarburnDSL50
    Aug 8, 2008
    14,902
    7,528
    Wetville
    Good gawd it is not just power tube that gives a Plexi it's sweet spot. It's both preamp and power tube mixed just right.
    And there are many spots along the way you can boost power tube to get great tone and feel.
    Some of these techs lack application or proper audio tests. Or lack the ability to use a Plexi throughout its volume and gain range. Speakers and pups mean quite a bit in a clear open Plexi amp. So many ways to affect the front end of a Plexi.
    It is not just power tube saturation. It's the mix between preamp and power section. If it was just power tube saturation then it would be farty and the volume would be so loud it would ruin tone and dynamics. Freaking techs sometimes need to play more. I respect them but there are times where they tell stories based on data. Guess what? Data can be a cold place. Stiff, sterile and unforgiving. Not what my plexis sound like at all.
    LRT#1, Big Mike, dreyn77 and 2 others like this.
  14. neikeel
    2,820
    1,308
    Think I just said that above - we agree absolutely!
    Big Mike and solarburnDSL50 like this.
  15. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    Since I am a guitar player, before anything else...
    The plexi is the clean preamp which overdrives the power amp into distortion compression.
    (the power amp clips before the preamp does...)
    Only drawback being: plexi is too loud when cranked to point of distortion.
    Otherwise this tone would be really ideal, if it were not for the loudness...
    That is why the factory added an extra preamp stage / master volume to the plexi.
    It's the 2203...
    Allows preamp distortion, overdriving phase inverter...but when the master volume is down, you lose the output tube distortion.
    This was the compromise. The output tube distortion sounds much better than preamp distortion.
    BUT it was too loud that way.
    The only real difference was that the low frequency is limited on the 2203...to prevent too much compression in the low frequencies. (which sounds muddy overloaded).
    This is done by changing the cathode bypass cap of V1A, to 0.68.
    Other than that the 2 amps are essentially the same amp, 2203 has the 2 preamp stages of a plexi, but ganged together in series....instead of separated in parallel. (this is also called "cascade.")
  16. stickyfinger
    Nov 11, 2010
    464
    142
    In a Plexi the PI clips before the power amp unless you consider that the power amp . I don't as its simply a gain stage paired with a inverting stage.
    OWM allows for a lot (and I mean a lot) more "sensitivity" than a 2203. RR OWM it and add a PPIVM. Now you got your Plexi and a hot rod cali amp.
    Or you could add a switch. I like the RR mod as the plexi looks stock nut once you plug in you'll know :hbang:
  17. Copperheadroads
    Oct 6, 2012
    112
    27
    what is the difference in Randy Rhoads OWM & the regular plexi with the OWM ?
    dreyn77 likes this.
  18. stickyfinger
    Nov 11, 2010
    464
    142
    Typical OWM removes one of the inputs, so no 68ks (formally the grid stoppers on the input of the amp) to ground on the second stage. The Vol pot before it is the ground so you can remove the 68ks for more gain. RR OWM lets you choose 2 or 3 gain stages by leaving the 68k grid stoppers in tacked. So classic 4 hole bright channel and hot rod OWM on normal inputs
  19. AlvisX
    AlvisX Well-Known Member
    May 31, 2011
    3,538
    5,640
    I-55 Corridor
    Im not a fan of one wire mods myself . Both my Major & my '73 1959 had it when I got each of 'em .....a squeally mess they were . I wish I'd taken pics
    The 100 watter I put back to my version of stock .....shared cathode /2x022 V1 couplers/250pf brite with an older trainwreck PPIMV....I have yet to try version 3 ,looking for a donor
    The Major ,a 2203 preamp made it into the most awesome thing
    I have no idea exactly what you guys are shootin for . I'd say Im more a classic Marshall guy and tend to tune my amps that way ....not much of a "gainiac"
    soundboy57 likes this.
  20. Kris Ford
    Jan 3, 2015
    1,050
    744
    Detroit FTW
    Wonder if this is why the gain is boosted when plugging a blank plug into Channel I HI and LO..mine is cascaded, and all 4 holes work...:hmm:
