What T-number Is That Celestion Speaker?
Discussion in 'Cabinets & Speakers' started by kuli, Feb 14, 2019 at 6:06 AM.
  1. kuli
    kuli Active Member
    May 10, 2011
    118
    28
    Hi guys!
    Looking at this auction:
    https://www.ebay.co.uk/itm/273662831176
    He is selling a T1234 from 1974 with a pulsonic 75hz cone - no problem there, but he claims he also got another 8 ohms G12H from 1974 but with a pulsonic 55hz cone - did a speaker like that even exist and if, what T-number/model-number does it have?
    I don't recall ever hearing of such a speaker...
  2. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,435
    1,004
    T1281 , but thought they only went into 1973 with pulsonic cones , It is of course entirely possible that there are 1974 date stamped ones out there .
  3. kuli
    kuli Active Member
    May 10, 2011
    118
    28
    No a T1281 is a 16 ohms speaker.
  4. kuli
    kuli Active Member
    May 10, 2011
    118
    28
    Ok, he actually says the year of the speakers is 1973 not 1974, but that doesn't matter in my question.
  5. Ufoscorpion
    May 4, 2013
    1,435
    1,004
    A grand for one speaker coz it's 8 ohm's , which is really only any use in a 1x12 , interesting . I've got a pair of 1973 t1281's with pulsonic cones that cost £100 for the pair . As a player and not a collector I'll stick with the 16 ohm versions it think , good information all the same if I happen to find any 8 ohm ones cheap . Need Bygone tones to step in and enlighten us on this one .
  6. kuli
    kuli Active Member
    May 10, 2011
    118
    28
    Actually in my 2x12" cabinet I use 2 x T1220's to get a 16 ohm cabinet that matches my THD HotPlate. Great for smaller gigs.
    Georgiatec likes this.
  7. Ufoscorpion
    May 4, 2013
    1,435
    1,004
    Series wired of course , I wire a 2x12 in parallel because apart from finding old speakers more common in 16 ohm it's safer .
  8. kuli
    kuli Active Member
    May 10, 2011
    118
    28
    The thing is, sometimes I am not able to bring my gear home until the day after the gig (driving-disabled), so I bring my JTM45 clone with a RS OT-clone set to 16 ohm, so I need a 16 ohms cabinet..
  9. Ufoscorpion
    May 4, 2013
    1,435
    1,004
    I do find it strange that hot plates are ohm specific , it's got to hurt their sales apart from anything else . Even with my £100 jetenuator I can use any ohm speaker cab over 4 ohm's ( just need to be matched to the amp at input either at 4,8 or 16 ohm's ) . My torpedo reload on the other hand has a switch to match 4,8 or 16 ohm's .
  10. BygoneTones
    BygoneTones Well-Known Member
    Aug 27, 2013
    991
    502
    T1460 probably. I think they mostly came in HH combos. Don't see them very often.
  11. kuli
    kuli Active Member
    May 10, 2011
    118
    28
    Actually THD says the hotplate can be used with different ohms, as long as the amps settings matches the cabinet - but there could be some EQ-losses when doing it.
    Brian, I had the feeling you might had an answer to my question!
  12. Ufoscorpion
    May 4, 2013
    1,435
    1,004
    Do you think the going price a grand , I find it hard to beleive anyone would pay that .
  13. BygoneTones
    Aug 27, 2013
    991
    502
    No chance. A grand for an absolutely mint, fully tested quad maybe.
  14. Gutch220
    Gutch220 Active Member
    Feb 19, 2018
    343
    153
    NJ
    Unless it was played by Jimi Hendrix's ghost, that's way over-priced. The seller seems to be relying on the hype. It's easy to make subjective claims on the superiority of rare items. (ex: the 8 ohm versions are louder and have a punchier low-end, and break-up more smoothly).......see, it's easy. :mrburns:
  15. Scumback Speakers
    Sep 16, 2016
    402
    400
    Los Angeles, Ca
    I put two T1234 75 hz 003 and two T1460 55hz /14 cones in a 68 straight cab I picked up 18 months ago. I couldn't sell these 8 ohm G12H30's for $300 USD each, even though they test out great. So I said the hell with it and put them in a cab I found locally in Santa Monica for $800. Glad I didn't sell them now, they kick serious butt. The T1234 are easier to find, but the T1460 I've only seen four in 20 years, glad I swiped up two of them. The other two went for stupid money, $500 USD each.
