What size pot? or not.
Discussion in 'The Workbench' started by junk notes, Mar 26, 2020 at 6:20 PM.
  1. junk notes
    junk notes Well-Known Member
    Dec 10, 2018
    437
    401
    I have a project and do not know how to do the math. (9v battery radio)
    What size pot can I use (something like a rheostat) that only needs to handle 12v or less, (9v continuous - 12v max).
    Or, do I just go to the home improvement store and buy a light dimmer for several dollars?
    It will go between the low voltage circuit to control a transistor radio speaker (8Ω-2w)
  2. ampmadscientist
    16,545
    10,454
    I think it's called an L-pad.
  3. junk notes
    Dec 10, 2018
    437
    401
    Alright.
    here is a simple layout.
    In the diagram t 'Amp' represents the transistor radio's circuit board red and black speaker wires coming off - going the to the tiny speaker. It looks simple enough to cut the wires and splice in the L-Pad in line as it shows.
    Thank you, appreciated. This should work, and was what I was trying to achieve. I knew there was something, did not know terminology. Will post results after install...
    What happens when you are Bored-19.
    Wooferhead1 likes this.
  4. ampmadscientist
    16,545
    10,454
    Be sure to boil any parts you buy till sterile.
  5. junk notes
    Dec 10, 2018
    437
    401
