What ODs Are You Guys Using in Front of Your Marshalls
Discussion in 'The Tone Zone' started by tallcoolone, Sep 28, 2019.
  1. tallcoolone
    tallcoolone Well-Known Member
    Mar 7, 2011
    1,144
    1,756
    [QUOTE="axe4me, post: 1875753[
    [/QUOTE]
    Not sure how constructive just posting random YouTube links is? More asking for opinions from guys with actual experience with the gear and it’s use
    netlocal likes this.
  2. tallcoolone
    Mar 7, 2011
    1,144
    1,756
    What does ‘need’ mean again??
    indeedido and netlocal like this.
  3. WellBurnTheSky
    Mar 23, 2019
    585
    1,337
    My go-to always was the Maxon OD9. Got my first one 15 years ago, no pedal ever managed to knock it off the board. Used it in front of my DSL, still use it for mild boost in front of the SV20H, it never disappoints.
    With the SV, for more boost (going for hard rock/early 80s metal territory), I've been using and loving my Guvnor clone. For yesterday's gig I subbed my OCD clone for it, and it sounded very good. I needed to dim the amp quite a bit (because of strict volume constraints at the event), and the OCD in LP mode provided the girth and compression that was missing. I liked it quite a bit. We'll see if it can manage to dethrone the Guvnor in the long run, but so far, so good.
    Other boosts I really liked with the SV are the Barber Drive, the Red Snapper and the Jersey Girl FullTender (which is basically a mod of the OD-1). For balls-out gain, I also liked the BJFe Dyna Red Distortion and the Ultra mod DS-1.
    But my first choices are any variation of the TubeScreamer, same with the Guvnor, and the OCD. Can't go wrong with these.
  4. JohnH
    JohnH Well-Known Member
    May 31, 2008
    3,907
    1,814
    Wilton NSW
    Ive got all the Hardwires on my board, and a Guv'nor. but the one I keep using is a Boss OD3, their best OD ever IMO.
    Neville and netlocal like this.
  5. axe4me
    axe4me Well-Known Member
    Feb 28, 2013
    6,222
    6,703
    I just discovered this...................
  6. WellBurnTheSky
    Mar 23, 2019
    585
    1,337
    I built a clone of this one too (Bjorn at BJFe/Bearfoot shares most of his circuits on DIY boards btw), and didn't really like it, tbh. To my ear, it was kinda wooly, which isn't something I like in a boost. It was pretty nice as a standalone overdrive on a clean amp though. YMMV obviously.
  7. tallcoolone
    Mar 7, 2011
    1,144
    1,756
    I agree about the OD9–that pedal is fantastic in front of a Marshall like the SV. I have to say, if you get a chance to check out the OD820 give it a shot
    netlocal and WellBurnTheSky like this.
  8. Midnight Blues
    Midnight Blues Well-Known Member
    Feb 21, 2011
    682
    436
    Either a Fulltone OCD or PlimSoul.
    netlocal and tallcoolone like this.
  9. tallcoolone
    Mar 7, 2011
    1,144
    1,756
    Can you give a brief review of the Plimsoul? I see them everywhere but never tried one out
  10. WellBurnTheSky
    Mar 23, 2019
    585
    1,337
    Will do, a souped-up TS (using a 18V charge pump) sounds pretty fun !
  11. Jethro Rocker
    7,905
    9,033
    I use an OD with higher level but zero gain on some channels, some amps. Adds some extra to the Jubilee, is essential with the 800 4010, and I sometimes goose ch 2 mode B on the 6101 and red mode ch 2 on the JVM410. The TSL on Ch 2 likes it too.
    I find ODs with simply a tone control to be lacking some low end IMO. I have an old Bad Monkey I really like for the 2 band EQ and recently picked up an MXR super Badass Distortion used the same way. It has 3 band EQ. It works for me.
  12. Mitchell Pearrow
    10,259
    17,152
    I only have 2 overdrive pedals
    SD1, Joyo Ultimate drive, but since I started using the mxr 10 band eq I have removed the od pedals, my 2 rigs are Dsl40c’s, and Origin 50H’s, each rig has a lead 100 mosfet along for the ride
    And I am truly liking the tones I can get from each rig!
    Cheers Mitch
    LPMarshall hack and netlocal like this.
  13. tallcoolone
    Mar 7, 2011
    1,144
    1,756
    Does the MXR EQ add a lot of hiss? I had a Boss EQ that was noisy as hell so I’ve been wary of the mass produced ones. I love using an EQ in front of a NMV amp as a ‘clean channel’
  14. Mitchell Pearrow
    10,259
    17,152
    I don’t get much hiss , but if you knock it around, it makes noise!
    Hope this helps!
    Cheers Mitch
    Trelwheen likes this.
  15. SkyMonkey
    1,947
    2,398
    Indoors
    For those out there who can't decide which OD to get, I can recommend the Source Audio L.A. Lady.
    It is expensive (£160), but is front switchable between upto 6 of a possible 40 classic OD simulations (and distortions and fuzzes), each with individually remembered knob settings. Stereo too (in & out), so parallel OD engines (or stacked). Editable by USB connected app.
    I had one for a while and loved it (even though I still didn't really understand how to use OD properly), but had to get a refund due to finances (to get a DSL40CR). I will get one again without hesitation when I can afford it.
  16. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    743
    1,041
    Custom tones ethos twe-1 into plexi. Don't know if it's love or lust but it's all- consuming.
    Mitchell Pearrow and tallcoolone like this.
  17. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,746
    4,127
    Springfield, Ohio
    The Wampler Tumnus Deluxe, if I need a little more gain, followed by the always on Exotic EP Booster set at 0.
    tallcoolone likes this.
  18. lespaul339
    lespaul339 Well-Known Member
    Dec 28, 2010
    553
    529
    Iowa
  19. ampmadscientist
    17,875
    11,919
    Don't really use any pedals.
    I just concentrate on getting the overdrive from the amp itself.
    And if I can't get a decent tone from the amp, I figure I need a different amp that works better.
    Don't really like the sound of transistors in boost pedals at all.
    lordquilton likes this.
  20. Midnight Blues
    Feb 21, 2011
    682
    436
    Sure. It's a very versatile pedal. It has both "Soft" and "Hard" clipping settings that'll allow you to take it anywhere you want, from a nice warm bluesy Fendery tone all the way up to a (insert metal amp name here) metal tone.
    For me, I'm kind of in the middle, i.e., getting the classic "British" tone and mainly use it on my Marshall 1974X, especially if my wife is home and/or I have the windows open. Yeah, it's only 18 Watts, but it's a LOUD :rock: 18 Watts!
