What Od Pedal Do You Use.
Discussion in 'The Tone Zone' started by Marcell, Dec 4, 2018.
  1. Marcell
    Marcell Active Member
    Feb 11, 2012
    234
    82
    Holland
    For the JCM 900 I found these.. I know some guys use distortion with their amps.. I like the OD pedal more I think... for 70 euro both..I had to buy them.
  2. Gutch220
    Gutch220 Active Member
    Feb 19, 2018
    199
    60
    You can still use an OD pedal in channel B to boost.
    I use a Maxon OD-9, and a Boss Blues Driver BD-2.............mostly I will use the OD-9 with humbuckers, and the BD-2 with single coils.
    Marcell likes this.
  3. JimiRules
    JimiRules Well-Known Member
    Feb 24, 2010
    2,667
    2,412
    Boss SD1 and a Keeley modded Boss BD2.
  4. Marcell
    Feb 11, 2012
    234
    82
    Holland
    It's perfect for channel b.
    It's marshall voiced. They used the Boss as a blueprint I think.
    That satchurator had to replace the Boss ds-1 .. I don't like that sound very much.. even on channel a it's to fizzy.
    Just bought a Vox time machine to go with the other pedal.. wah, overdrive and delay.. I don't need more. Delay was expansive..72 euro with postal cost.
  5. Herbert Mitchell Pearrow
    Herbert Mitchell Pearrow Well-Known Member
    2,772
    2,120
    SD1 it’s the only od pedal I have, maybe one day when I have more dough to spend I will try something else but at this time it is only the SD1
    Marcell likes this.
  6. sv102
    sv102 New Member
    Nov 22, 2016
    24
    10
    Mojohand FX Odessa seems to be working well.
    Marcell likes this.
  7. jmp45
    jmp45 Well-Known Member
    May 5, 2016
    1,186
    1,134
    OCD, Full Drive and old script logo Nobels ODR-1. Bad Monkey too.
  8. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,288
    821
    I'm liking a rat clone and ( Tomsline black teeth , don't let the £19 price tag fool you ) and an Orange getaway driver .
    Marcell likes this.
  9. Marcell
    Feb 11, 2012
    234
    82
    Holland
    Do you get most overdrive from the amp or the pedal? Never used it this way...
    I tried it today.. on the od channel B it is hard to control at high volumes..just need to tweek it more I think.
  10. MonstersOfTheMidway
    May 1, 2008
    4,547
    1,801
    Since purchasing my JVM410H back in 2007, my distorted/overdrive/dirt tone comes almost always from the amp itself, but I think I've used an od/distortion/dirt pedal from time to time.
    When I do use distortion/overdrive/dirt pedals, it's usually an original Boss SD-1 from the 1990's or a T-Rex MudHhoney pedal. There are a few other OD/distortion/dirt pedals I've used over the years, but those two really tap into the particular OD/distortion/dirt that I like for certain situations.
    If I'm every using a different amp that isn't quite giving me what I want, I usually set the amp to clean (or "clean-ish"), then stick either the SD-1 or Mudhoney in there and it's instant gratification.
  11. AlanH
    AlanH Well-Known Member
    Jul 2, 2017
    450
    401
    UK
    SD-1 for more gain and compression when needed
    Bad Monkey set as a clean boost for solos
  12. SlyStrat
    SlyStrat Well-Known Member
    Jan 7, 2011
    736
    271
    Cleveland, OH
    Tried almost every OD made.
    Barber Direct Drive Compact knocked them all out.
  13. Jeff Hudson
    Jeff Hudson Active Member
    Jul 10, 2016
    148
    95
    Levelland Texas
    Keeley mod Blues Driver, MXR Prime Distortion currently. Keeley is my current fave. Out of what I used to use I would buy another BK Butler Tube Driver.
    JimiRules likes this.
  14. Shae201
    Shae201 Well-Known Member
    Dec 20, 2015
    488
    422
    For amazing Progressive, Thrash and Power metal tones I like the TS808 Fromel mod and a Voyager or Archer through my 79 JMP. I also like the Soul Food.
  15. JimiRules
    Feb 24, 2010
    2,667
    2,412
    I love my Keeley BD2. I've never used a stock one, so I really couldn't say what the changes are over the stock version, but it has more balls than my SD1. I like stacking them. I set both as clean boost, so there's not a crazy amount of gain going on. If I need a bit more oomph over my rhythm sound I use the SD1. If I need a bit more I will use the Keeley BD2. Then for leads I kick both on.
  16. Jeff Hudson
    Jul 10, 2016
    148
    95
    Levelland Texas
    JimiRules, the keeley is my desert island pedal for sure, I really don't use anything else pedal wise for drive. It's my one stop shop for out board dirt. the MXR is only used for when I want a rattier drive tone which is not very much. The stock BD-2 did not do anything for me.
    Marcell and JimiRules like this.
  17. JimiRules
    Feb 24, 2010
    2,667
    2,412
    Is it weaker than a stock SD1?
  18. Marcell
    Feb 11, 2012
    234
    82
    Holland
    A compression pedal is on the list.. years ago I had a dyna comp from the 80's... with my stupid head I devided to sell that.. now they want top privé!
  19. Jeff Hudson
    Jul 10, 2016
    148
    95
    Levelland Texas
    I'm not familiar with how those two compare to each other, I never got into the boss pedals too much.
  20. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    896
    933
    Texas
    I have several that I use for different things.
    Maxon TBO-9
    Maxon OD-808
    Marshall DriveMaster
    Catalinbread Naga Viper
    Mesa V1 Bottle Rocket
    Blackstar HT Drive
    * Xotic EP Booster - not an aggressive pedal, nor is it a true OD, but it's glorious sounding and will grow a little hair when you crank it
