What does it sound like if cathode follower/PI Tubes have died?
Discussion in 'The Workbench' started by Sandwell, Oct 18, 2019.
  1. Sandwell
    Sandwell New Member
    Feb 28, 2017
    27
    The other day my Marshall DSL 50 started sounding weird, it basically sounds shrunken and a bit collapsed. I put in my spare set of output tubes but it sounded the same. The amount of gain hasn't changed so I'm thinking V1 and 2 are fine. Could the cathode follower or phase inverter have died? is this what it would sound like? I have EHX 12AX7s in all positions and I've just read that russian tubes arn't the best for the cathode tube...
    Cheers
  2. anitoli
    anitoli Well-Known Member
    6,622
    7,325
    When in doubt, swap em' out. Tube exchange is one of the first and easiest trouble shooting tricks you do to isolate the problem.
    johan.b likes this.
  3. RobS
    RobS Active Member
    Apr 19, 2009
    892
    143
    Melbourne - Australia
    had a similar thing years back with my 2203. basically the 2nd pre amp tube had failed in my case (tung sol)
    sound was there but weak or collapsed as you describe
    changed the 2nd tube and all good again
  4. ampmadscientist
    13,872
    7,709
    It could be a bad circuit board, look me up if you want to test the board....
  5. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,521
    1,540
    Södertälje, Sweden
    I'm with anitoli..
    .. there is a reason tubes, the most vulnerable parts of your amp, sits in sockets on the outside of the chassis and not soldered in, on the inside.
    J
  6. ampmadscientist
    13,872
    7,709
    The circuit board plugs in, just like the tubes do...
    I would check that first considering.
  7. Sandwell
    Sandwell New Member
    Feb 28, 2017
    27
    V2 in a 2203 is the cathode follower so I will swap that one out, thanks
  8. MarshallDog
    Nov 28, 2010
    11,825
    10,765
    Taintville
    The PI is the hardest working tube in the amp, it should be changed with the power tubes!
  9. Sandwell
    Sandwell New Member
    Feb 28, 2017
    27
    I did not know this, thanks
  10. Sandwell
    Sandwell New Member
    Feb 28, 2017
    27
    It was the cathode follower tube
    johan.b likes this.
