What are your favorite cheapy pedals?
Discussion in 'The Tone Zone' started by bobpick68, Nov 10, 2019.
  1. bobpick68
    bobpick68 Well-Known Member
    Sep 4, 2018
    365
    695
    Yup for sure!
    jmp45 likes this.
  2. AlvisX
    AlvisX Well-Known Member
    May 31, 2011
    4,072
    7,285
    I-55 Corridor
    I'll have to check that out . Ive sworn by the 250 for near 40 years
    It would be perfect for my mini / airplane board
    Thanks for the tip
    stringtree and Mitchell Pearrow like this.
  3. Filipe Soares
    Mar 8, 2019
    646
    1,002
    It's an amazing pedal, the only downside is the volume pot is inside (trimpot). in my case the volume is always on 10, because I use it as a boost or like yngwie.
    stringtree and bobpick68 like this.
  4. AlvisX
    May 31, 2011
    4,072
    7,285
    I-55 Corridor
    I figured the pot was inside
    I looked it up, looks like they changed it , level & gain on the outside and some kind of toggle switch ....EQ variation or something ,perhaps
  5. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,633
    4,192
    Austin TX
    The Donner stuff has been pretty impressive for me. The Boost Killer is a favorite, I have multiples of them. Looks to be the same as the Mooer Pure Boost - a clean boost with a bit of gain/OD available and tone controls.
    https://www.donnerdeal.com/products...ler-guitar-effect-pedal-rich-distortion-sound
    The Yellow Fall is a surprisingly good compact echo.
    https://www.donnerdeal.com/products/donner-yellow-fall-delay-guitar-effect-pedal-true-bypass
    The DeltaLab stuff was good too, I have the analog chorus and OD.
  6. houseofrock
    houseofrock Well-Known Member
    Jul 10, 2015
    809
    890
    Florida
  7. progrockabuse
    progrockabuse Member
    Jul 20, 2019
    41
    72
    I've currently got 3-4 of the cheap mini pedals, which i brought since i had my Origin 20. I've found the origin to be a great pedal platform compared to my Orange Dual Terror that was very picky about what pedals it played nicely with.
    Currently favourite is the NUX Brownie, which is pretty much a Plexi in a pedal kinda deal. I've been using it with the gain around 9/10 o clock and volume and tone to taste. Pretty convincing at lower volumes and the dynamics you can achieve from pick attack and guitar's controls are amazing. I'd say i like it as much as i liked my SL drive when i had it, so not too bad for a £12 pedal.
    I've got the Mosky Klon clone which is a pretty nice od, i like to chain this after the Nux Brownie for a nice mid-rich boost for lead work.
    For delay, I've got a cheap analogue delay from a company called Muzizy, which is just a rebadge of some of the other cheap Chinese pedals. That was only £12 as well, and again not a bad little delay pedal. As long as i can get the "Run Like Hell" delay setting going, then that delay is a winner for me, and this one does it with some careful setting of the level and feedback.
    I miss my old Danelectro PB&J delay pedal, that was great for the £30-40 it cost me new back in the day.
  8. Lukas
    Lukas Well-Known Member
    Apr 21, 2013
    280
    335
    Canada
    Agreed they’re amazing. I own the corona chorus and flashback delay minis both hooked up to my DSL 40CR. Kicks ass.
    rick16v likes this.
  9. Filipe Soares
    Mar 8, 2019
    646
    1,002
    mosky pedals are a great surprise. give a try to the blue delay (mad professor), one of the best delays I´ve owned.
    progrockabuse likes this.
  10. progrockabuse
    Jul 20, 2019
    41
    72
    I keep seeing that one and think it's worth grabbing.
    Currently on a quest to find a decent cheap octavia or fuzz face.
  11. axe4me
    axe4me Well-Known Member
    Feb 28, 2013
    5,466
    5,603
  12. Mitchell Pearrow
    8,825
    13,472
    That’s too bad, I still have both of mine. Don’t see them going anywhere.
    But as they say, play what inspires you.
    Cheers
    stringtree likes this.
  13. wntbtw
    wntbtw Active Member
    Nov 17, 2010
    219
    240
    I have 2 Joyo pedals--'Crunch Distortion' [which, if you want MASSIVE BOOSTED overdrive, this is a great pedal as it gets so LOUD! It`s a fun pedal even w/ the volume set at 'unity']. And I also have their phase shifter which also is a fun if you want that 'swirly stuff'. I just ordered their version of the classic Tubescreamer ['Vintage Overdrive'] & based on the reviews, I look forward to seeing what it can do. I am really not 'into' pedals because I mainly play at low/bedroom volumes but just am curious. The tones I like are given to me thru either of my two 20w hot-rodded Ceriatone amps [Yeti & Chupacabra]. I play these OD pedals [as I also have the SD-1, Danelectro 'Transparent OD V-1', & the 'Bad Monkey'] thru the Low Input of my JCM 800 2204 combo at a low volume.
