What’s A Good Transformers Set 4 An 1981 2203?
Discussion in 'Marshall Amps' started by fifteenohms, May 13, 2019.
Tags:
  1. fifteenohms
    fifteenohms Well-Known Member
    Sep 30, 2010
    1,071
    541
    Los Angeles, CA
    Whats a good recommendation for a 2203 replacement set?
    I didn’t like the Mercury’s- anyone?
    Thx
  2. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,787
    1,561
    Ive never had to buy any transformers but if I needed to I probably would'nt look any further than one of this sites sponsors ' Classic Tone ' .
    Bluesrock and 67Mopar like this.
  3. lespaul6
    lespaul6 Active Member
    Dec 13, 2007
    107
    85
    Florida
    What didn't you like about the MM trannys? the tone clone is a copy of the dagnall.. The primary impedance is most important 1.7k I think? Did the internet get you to believe in the old paper vs plastic mythology?
  4. ampmadscientist
    18,091
    12,131
    Did you replace good transformers? Or was there something actually wrong with the originals?
    Were you convinced that changing transformers would make the amp work/sound better?
  5. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    1,917
    2,405
    I know that tone is subject to the individual, but to my ears, Mercury iron has a sort-of "tearing paper" sound between the midrange and top end. Could be modern tubes, I don't know? Friedman amps have this sound, though I don't think he uses Mercury Magnetics transformers. Classic Tone iron seems to sound closest to Marshall OEM.
  6. Gunner64
    Nov 16, 2013
    6,035
    7,699
    Midwest, USA
    Classictone. Excellent tone, quality and a good value.
  7. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    672
    1,468
    WA state hinterlands
    Watch the PT B+ voltage vs the voltage rating of your power tubes.
  8. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    8,248
    5,131
  9. fifteenohms
    Sep 30, 2010
    1,071
    541
    Los Angeles, CA
    Yeah I did remove good stock ones, because a few guys recommended that, and then internets said convincing stuff.
  10. fifteenohms
    Sep 30, 2010
    1,071
    541
    Los Angeles, CA
    The Mercury’s lost the “whomp” the stock ones had and now the thing reacts to strings real linear.
    Linear is for stereos.
  11. boola1
    boola1 Well-Known Member
    May 17, 2016
    355
    260
    Not sure if that's sarcasm, if not, you've had some bad advice.
    A 1981 2203 was fitted with the classic transformers that people generally attribute to why the old amps sound better. I'm certain you wont get any responses here other than "put the originals back in".
  12. fifteenohms
    Sep 30, 2010
    1,071
    541
    Los Angeles, CA
    Let’s be clear: the Internet’s can be blamed for a lot of bad information we mistakenly followed in hindsight.
    Speaking of which, I DID as suggested and visited the above advertised xformer site and may try a set from them!
    I was looking for more headroom, Plexitone squeal & sizzle than stock.
  13. boola1
    May 17, 2016
    355
    260
    Well the Super Lead 100w used exactly the same transformers so you're barking up the wrong tree there. You need to investigate other mods or a different amp.
  14. neikeel
    4,237
    2,687
    I have use and will use again Marstran specc'd Heyboers (the Metro ones are the same AFAIK and made by same manufacturer). I have also used Merren OTs and was very impressed, pretty sure he winds his own, bit more expensive. I have a classic tone OT in JMP clone - yet to fire up. I found the Mercury in a JTM45 build very sterile (and yes linear) I replaced it with one of George's metro specc'd -103s and the amp was transformed (ha, ha...) with much more complex tones.
    I do think in a true 'metal' amp the Mercury might do well.
    Oh and I am always looking out for original Dagnall's and Drakes, although the PTs are often blown so take care.
  15. fifteenohms
    Sep 30, 2010
    1,071
    541
    Los Angeles, CA
    I think you nailed it with the term “complex tones” for the effect I’m seeking from the new set I need
  16. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,714
    1,943
    Södertälje, Sweden
    Internet... internationally not entirely true
    .. put the originals back in, that's the sound you're chasing..
    J
    Mitchell Pearrow and spacerocker like this.
  17. ampmadscientist
    18,091
    12,131
    A. First of all, a different transformer will not give you more headroom. That's not possible.
    B. If you want a different sound, try using different preamp tubes it can make a big difference.
    C. Changing transformers will not make any magical change in the performance or sound, it will be almost the same.
    D. There is nothing wrong with stock Marshall transformers, and they are really good transformers.
    There is a lot of misinformation on the internet concerning transformer changes.
    Most of it is just BS sales hype.
    Some sales people will tell you that your tone is going to be vastly improved - it's just bullshit.
    They want your money and they don't care what your amp sounds like.
    In other words: You were taken by sales BS.
    The way to change / improve the sound of an amp: is in the preamp and speakers, not the transformers.
  18. fifteenohms
    Sep 30, 2010
    1,071
    541
    Los Angeles, CA
    Partially true: the mistake was not selling $300 transformers I paid $220 for with the amp complete, nor becoming good friends with a great American shop in Sergio and at the time Paul.
    Things I learned from them and about their shop and product developments were priceless. You can’t but that and I respect Mercury in all they do.
    Any question I had, any design, brand, year, core structure,”square vs round” magnet wire got an immediate answer. plus the reasoning behind it all “why this why that” they were very patient.
    I was glad to pay, and I did make $50 when I sold that set also- but was it just a waste of time that took me? Or did my own tone-chasing madness push me I don’t know exactly.
    But I have many tubes and speakers in my collection - thanks for those kind suggestions - which is why I sought out that last unknown fork in the road to me which was interaction of the OT & power supply.
  19. fifteenohms
    Sep 30, 2010
    1,071
    541
    Los Angeles, CA
    The originals went on CL years ago very quickly
  20. Trumpet Rider
    Trumpet Rider Well-Known Member
    Nov 8, 2016
    1,817
    3,047
    This is probably the best Transformers set.
