Weird Issue With My Dsl. Just Started Happening Two Days Ago...
Discussion in 'The Workbench' started by justinrhoads80, Nov 26, 2018.
Tags:
  1. justinrhoads80
    justinrhoads80 Well-Known Member
    Dec 18, 2017
    1,447
    868
    Roseville, California
    I just started having this issue a few days ago and I unplugged the amp included all the cables for a day to let it sit.
    Any idea what I can do to resolve this? Any idea wth is going on?
  2. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    8,248
    5,120
    Tube problem would be my guess.
  3. justinrhoads80
    Dec 18, 2017
    1,447
    868
    I think so too, but in another group page some said that it could also possibly be a cable issue. Plugged the guitar straight into the amp and didn't experience the issue. But after trying it with another guitar it sounds super mega microphonic. I will be doing more in depth troubleshooting tomorrow after weight lifting so hopefully it gets resolved
  4. ricksconnected
    Sep 29, 2015
    13,388
    6,632
    everywhere you wanna be.
    is that you Justin?
    in for the answers.
  5. pedecamp
    13,649
    9,957
    Do you have any electronic cleaner like Deoxit? I'd start by cleaning all your tube sockets and reseating your tubes. Clean all your inputs and pots too. Clean all your pedal inputs too and guitar inputs. If its still a problem you might have a bad tube, test all your tube positions with a known good tube.
  6. justinrhoads80
    Dec 18, 2017
    1,447
    868
    Always asking questions. Always feeding on new knowledge and such. Can never have enough
    ricksconnected likes this.
  7. Micky
    Apr 29, 2010
    20,450
    16,709
    Vermont
    Have you tried your spare tubes?
    Have you tried direct in with no FX?
    Have you tried with a different guitar?
    Also try direct into the FX return (will be loud)...
    Have you cleaned all the jacks?
  8. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,453
    3,499
    Springfield, Ohio
    Sounds like arcing JJ power tubes. My DSL 50 did this a while back. Drove me nuts thinking it was a bad cord or connection. It eventually popped a fuse and I took it to the shop. The shop was really cool and didn't even charge me for the service. He turned it on and saw the power tubes arcing.
    justinrhoads80 likes this.
  9. justinrhoads80
    Dec 18, 2017
    1,447
    868
    What is this "arcing"? What do I have to check to see if this is the issue I am having
  10. justinrhoads80
    Dec 18, 2017
    1,447
    868
    I plugged it in direct and no issues.
    I tried a different guitar (not plugging it in directly) and same issues on that guitar aswell
    Did not try direct into the FX.
    I will clean the jacks
  11. charveldan
    Jan 31, 2010
    8,248
    5,120
    Turn the amp around. Look for sparks flying inside the power tubes as you're playing and the amp is cutting out.
    Question : does the amp cut out when you plug the guitar straight in no pedals ?
    Does the amp cut out with a different guitar ?
    If yes to both try a different instrument cable.
    Jiggle the input jack if possible to see if its loose.
  12. Michael Roe
    Mar 25, 2017
    1,453
    3,499
    Springfield, Ohio
    "Arcing", what he said. Sparks or tiny lightning bolts inside of power tubes. If you see it, then power down immediately and get new tubes. This can also cause more damage if let to continue.
  13. justinrhoads80
    Dec 18, 2017
    1,447
    868
    It is now doing it when I plug it in directly..... I unplugged everything from the amp and only had the power cable in and i started lightly tapping the backboard of the amp and it started making that scratching sound so I am at a loss here
    @Michael Roe @Micky @ricksconnected @pedecamp
  14. Micky
    Apr 29, 2010
    20,450
    16,709
    Vermont
    Have you tried new finals?
    Make sure you bias it after replacing them...
  15. justinrhoads80
    Dec 18, 2017
    1,447
    868
    what do you mean new finals?
  16. Micky
    Apr 29, 2010
    20,450
    16,709
    Vermont
    Power tubes. The final section of the amp.
    Sorry, old term used by us radio nuts...
    Put in your spare set and bias it up to see if it still does it.
  17. MarshallDog
    Nov 28, 2010
    12,595
    12,266
    Taintville
    Like others have already said, just retube the whole amp...that more than likely what is causing the issue. Preamp tubes are cheap and stock Marshall ones are not that good IMO. While in the amp, check to make sure all the connectors are well seated and tight, clean all jacks and hopefully you should be good to go.
  18. justinrhoads80
    Dec 18, 2017
    1,447
    868
    Hey thanks for the responses. I do not have a spare set of Preamp tubes. I also do not really plan on keeping my DSL much longer since I am saving up for a Kemper. Is there any way that buying another set of preamp tubes will fix this issue?
  19. MarshallDog
    Nov 28, 2010
    12,595
    12,266
    Taintville
    If the issue is in a pre-amp tube then yes. If its in the power tubes then no.
  20. justinrhoads80
    Dec 18, 2017
    1,447
    868
    How can I determine if it is a pre-amp tube? Will I just have to buy a new set, swap old with new and find out from there?
    I originally thought it was a cable issue since that seems like that would be an issue that could be viable. When I heard that same crackling weird sound when NOTHING was plugged in I new that it was something more than that so that raised a bit of concern for me last night when I was doing some troubleshooting
