watch this guy make a fool of himself.....
Discussion in 'Guitars' started by Michael Roe, Jan 6, 2020.
  1. Michael Roe
    Michael Roe Well-Known Member
    Mar 25, 2017
    1,518
    3,572
    Springfield, Ohio
    Then look at this thread I posted here a while ago.
    http://www.marshallforum.com/threads/epiphone-gibson-differences.107337/#post-1824742
    Is this guy right? or am I?
  2. JeffMcLeod
    JeffMcLeod Well-Known Member
    Sep 28, 2017
    1,367
    1,888
    Whew! I saw the title, and I thought you were re-posting one of my videos. :rolleyes:
  3. Mitchell Pearrow
    9,030
    13,889
    Me too lol;)
    tce63 and Michael Roe like this.
  4. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    605
    459
    Both of you are right?
    Yes, pickup spacing varies a little on different LP models and on different SGs.
    But all SGs have the pickups closer to the bridge than LPs. (Except for mid/late '70s SGs.)
    The fretboards on both are the same length. But LPs have the neck pickup butted up to the end of the fretboard and SGs have a big space between the fretboard and pickup.
    There's less difference for the bridge pickups, but generally SG bridge pups are a little closer to the bridge.
    That makes the neck position and middle position sound significantly brighter, and the bridge position a little brighter.
    Pickup position is one of the biggest contributors to the difference in tone between LPs and SGs.
    The other big contributor is the unsupported length of the necks. LPs are mounted to the body at the 16th fret, SGs are free all the way to the 19th. Plus the neck/body join is a lot weaker and more flexible. The "longer" SG neck is whippier -- the attack is a little softer, and some bass gets absorbed.
    A lot of people attribute the tone difference to the thin body and lack of a maple cap. That does play some role (particularly because of the weaker neck joint) but most of the difference is the pup positioning and long neck.
    South Park likes this.
  5. South Park
    1,405
    1,058
    Great video . Explains a lot harmonics is a big part of all this
  6. RLW59
    Nov 30, 2017
    605
    459
    Visually misleading things -- many modern SGs have 24 fret fretboards where the fretboard does butt up to the neck pickup. But the pickup is in the normal SG place -- they just extended the fretboard to cover the normal gap where the neck tenon coverplate usually goes.
    SGs with angel wing pickguards can look like their bridge pickups are positioned differently than on batwing SGs. But the lack of a pickup ring and lack of bare wood between the pup and bridge tricks the eye and makes the pup look farther from the bridge on batwings.
    (Force your eyes to focus on the length of the strings from the center of the saddles to the polepieces -- they're the same on batwings and angel wings.)
    There's some tolerance/slop-factor in pickup placement. The CNC routs the cavities precisely, but they just eyeball mounting the rings. So can be off by maybe 1/16" in any direction.
    But the SG neck pickup is more than 1/2" closer to the bridge than a LP neck pup. No matter how the tolerance variations line up, SG neck pup is significantly closer to the bridge.
  7. South Park
    1,405
    1,058
    The two guitars where never meant to be the same one is high end one is mid range. That is way the necks are different
  8. junk notes
    junk notes Active Member
    Dec 10, 2018
    250
    234
    Good for him, that he just found out about the wheel.
    Guess he did'nt watch the video...
    Lester Polsfuss / Seth Lover have made it easy for him.
