Vintage Super Lead 100 Problem, Please Help!!!
Discussion in 'The Workbench' started by Frank Plante, Dec 23, 2018.
  1. neikeel
    3,764
    2,160
    I might have a spare.
    The ceramic were used to minimise arcing, clearly not good enough in this circumstance!
    I have both amphenol and similar too. I am sure I can spare one if you show exactly which type you need. I’m in UK.
  2. ampmadscientist
    15,419
    9,289
    Arcing isn't really a problem even w/ a smaller socket, provided speaker impedance is correct. When mismatched load is connected, then it arcs bigger socket or not.
    For some reason around period of transition between turret board and PC board models of 1959, they used this socket for about a year I have no clue why.
    Then they went back to smaller sockets.
  3. neikeel
    3,764
    2,160
    1971.
    I’ve had a couple of them. First time I’ve seen arcing with the ceramics.
    The amp in the pics has had some odd things done to it as well.
    It is the relatively rare one with Drake trannies. I had an SB with them.
  4. ampmadscientist
    15,419
    9,289
    Seems like those big sockets are harder and harder to find.
    I have 2 Millen sockets and they cost like $40 each. I think I maybe can find them if anybody gets desperate.
    But even Millen Co. seems to have disappeared now, find no trace of them anymore.
    Does anybody know what happened to Millen?
  5. ampmadscientist
    15,419
    9,289
    I found some new sockets located in Greece
    https://www.ebay.com/i/192351063871?chn=ps
    You can get 4 or 5. This is a reasonable price.
  6. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    730
    527
    NJ
    Why are those so special/rare?
  7. neikeel
    3,764
    2,160
    That is a good price (shipping to US is very cheap too).
    I have two sorts of Amphenol (plain hole and slotted mounting holes), an EICO and some Cinch ceramic octals. The rest are brown/black McMurdos, Amphenols and the like.
    I'd grab the Greek ones, I can't do just post that cheap!
  8. ampmadscientist
    15,419
    9,289
    The sockets were made for radio transmitters. 5000 volt plate supplies.
    The mounting hole is 31.75 mm instead of the usual 28mm so a normal socket won't fit.
    You could put in adapter plates to mount smaller sockets...that's about it.
    The sockets were easier to get for several years but now everybody seems to be running out of them.
    Tube radio transmitters are becoming obsolete and the parts are going to be hard to buy.
    I bought Millen sockets because they fit, but 4 of them cost like $140. Nice sockets they are but now even Millen has disappeared somewhere...
    So now people who own 71 Plexi will be scrounging around when a socket burns.
    Same problem for Sunn tube amps too, which also used Millen sockets.
    I guess you could use plastic ones but not nearly as good.
    Looks like you gotta buy adapter plates from now on.
    Those sockets in Greece: just buy all of them.
  9. Frank Plante
    Frank Plante New Member
    Dec 23, 2018
    18
  10. Frank Plante
    Dec 23, 2018
    18
  11. ampmadscientist
    15,419
    9,289
    Those are probably the best ones you can find that fit.
  12. ampmadscientist
    15,419
    9,289
  13. FourT6and2
    FourT6and2 Active Member
    Dec 3, 2010
    472
    242
    Man I'd love to get my hands on an original turret board Plexi or JCM800.
    I'm sure you'll get it sorted out, good luck.
  14. Frank Plante
    Dec 23, 2018
    18
    They sure sound great haha! Thanks I should be able to change the sockets pretty soon
