Vintage Super Lead 100 Problem, Please Help!!!
Discussion in 'The Workbench' started by Frank Plante, Dec 23, 2018.
  1. ampmadscientist
    15,421
    9,295
    This type socket is a special type that was only used in 1971 (I do believe).
    This socket has a metal retainer (snap ring) ring around the socket.
    This socket has a flange plate which is removable.
    The chassis cutout diameter of this socket is 1.25" or 31.75 mm, is larger than a normal Marshall socket.
  2. Frank Plante
    Frank Plante New Member
    Dec 23, 2018
    18
    Alright! I'll be able to attempt this with him in about a week or 2, let's hope it works! Thanks for your help, if the problem persists I'll come back here thanks again
  3. ampmadscientist
    15,421
    9,295
    There's several things you need to do including checking your speakers, speaker cables, jacks, impedance selector plug.
    Any of those can make the sockets arc.
  4. Frank Plante
    Dec 23, 2018
    18
    I have already checked all those and they are working correctly, maybe it wasn't used properly in the past? that would be my best guess. Speaker cab is wired correctly, the speaker cables are new, amp head is set on 16ohms (i have a 4x12, and the back of the speaker indicate 16ohms) . What do you think about the filter caps failing? Would that cause that kind of problem?
  5. m1989jmp
    m1989jmp Active Member
    Apr 24, 2014
    917
    150
    I'd say change the filter and bias caps regardless; they're cheap enough and can cause a lot of expensive failures when they finally fail.
  6. ampmadscientist
    15,421
    9,295
    The tube sockets arc because of impedance mismatch.
    Then if the sockets are burned they need to be changed.
    Mismatch can happen if the impedance selector plug in the back of the amp is worn out....making intermittent contact. (this selector plug is a weak point which fails)
    A bad speaker cable.
    Bad connections inside the cabinet.
    Bad speaker jacks that no longer make good contact.
    Blown speakers (speakers that scrape when they move in/out).
    Or any of this could have happened long ago. Before you owned the amp.
    Any socket which is burned must be replaced.
    The screen grid resistors must be changed (at least 2 of them look burned).
    The speaker must be matched to the amp.
    The bias must be adjusted correctly.
    The output tubes must be good (if these have not been damaged).
    The capacitors do not cause sockets to arc.
    But if the caps are old, you should change them. Those can fail from age.
    1. Connect a speaker cable to the cabinet.
    2. Connect an ohm meter to the end of the speaker cable.
    3. What is the reading? This is really important.
  7. ampmadscientist
    15,421
    9,295
    "...a sort of loud static-like sound when I play..."
    Yes I see why - because the sockets are arcing / sockets resistors are burned.
    All this stuff must be corrected before you play the amp again.
    Where are you located? I'm going to maybe recommend a tech.
  8. Frank Plante
    Dec 23, 2018
    18
    I am located in Quebec City, in Canada. Do you know where I could buy the sockets? I want to be sure I buy the right thing, especially if they are a special type.
  9. ampmadscientist
    15,421
    9,295
    Can you get a better picture of that socket? I can't see it very clearly, where it looks like it burned.
    Do any of the other sockets have burn marks?
    I need to see who has those bigger sockets in stock. Yes somebody will have some...
  10. Frank Plante
    Dec 23, 2018
    18
    Sure, does this help?
  11. ampmadscientist
    15,421
    9,295
    It's not the same brand as original, but it fits the (oversized) hole. It's made by Amphenol or Millen.
    It has a retainer ring and a mounting flange that holds it together.
    https://www.ebay.com/itm/AMPHENOL-8...h=item25f62d50de:g:1nIAAOSwHhRa9ku~:rk:5:pf:0
    This is Millen socket 33008, I have used it in these amps before because it fits the over-sized hole.
    Millen 33008 Steatite octal tube socket flange for 1.25" / 31.75 mm diameter hole
    1.625 center-to-center mounting holes.
    Bottom mount, mounting flange can be removed so it can mount in the same keyed holes as Amphenol 78/86 series.
  12. ampmadscientist
    15,421
    9,295
    On this one socket pin 2 is definitely arcing to pin 3.
    You need to replace at least this 1 socket.
    Do any of the other sockets look burned? check really carefully for any other burned spots.
  13. Frank Plante
    Dec 23, 2018
    18
    Thanks, do you suggest I change all 4? If so, is there another post that sells 4 of them? I believe I saw a guy that sold 4 black ones in the tab
    "People who viewed this item also viewed" , but again i cant post a link down here.
  14. Frank Plante
    Dec 23, 2018
    18
    I will check and attach more pics
  15. Gutch220
    Gutch220 Well-Known Member
    Feb 19, 2018
    730
    527
    NJ
    Could this type of arcing be caused by somebody erroneously turning on the amp without a speaker load? I bet a lot of people do this.
  16. ampmadscientist
    15,421
    9,295
    Check around to find 4 clean ones....but so far only 1 is really bad.
  17. ampmadscientist
    15,421
    9,295
    yes that is possible
    but usually set amp 16 ohms, hook up 4 ohm cabinet is what does it.
  18. ampmadscientist
    15,421
    9,295
    The black ones are plastic, which are not as good as the ceramic ones.
    So if you can find ceramic for a 1.25 inch / 31.75 mm hole that would be better.
  19. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    1,881
    1,339
    Las Vegas, NV
    @Frank Plante
    You said you checked that your speaker cables are good, but no asked if they are actual speaker cables or shielded cables? If shielded, this must be corrected! You also have not answered the question about the "measured" DC ohms resistance of your cabinet? Should read 12Ω to 13Ω-ish, for a 16Ω cabinet.
    Just Sayin'
    Gene
  20. ampmadscientist
    15,421
    9,295
    Or it could have happened before he bought the amp.
    (impedance mismatch)
    But he should test all that stuff anyway to be on the safe side.
