Vintage Super Lead 100 Problem, Please Help!!!
Discussion in 'The Workbench' started by Frank Plante, Dec 23, 2018.
  1. Frank Plante
    Frank Plante New Member
    Dec 23, 2018
    18
    Hey everyone,
    I have a vintage JMP Super Lead 100 and it started making a sort of loud static-like sound when I play. It doesn’t have any problem if I don’t play, and the problem seems to increase as I increase the treble/presence. I have tried the head with another cab, it has the same problem. I took it to two different techs, they couldn’t fix it. I changed the preamp and power amp tubes, I cleaned the tubes sockets, nothing seems to work and I’m getting pretty desperate because it really is a killer amp and I don’t have any ideas anymore. Can somebody help me?
    By the way, is it possible to send a video or an audio file so that you can see or at least listen to the sound it makes? I'm don't seem to be able to.
  2. ampmadscientist
    15,493
    9,382
    (Bump this to Workbench?)
    Yes we will help you.
    You need to make several posts before you can attach files...but yes you can attach a sound cloud or you tube file.
    We will probably ask you to measure inside the amp with a volt meter, can you do that?
    Can you take pictures of the inside of the amp?
  3. Frank Plante
    Dec 23, 2018
    18
    Thank you so much!
    I can't even post google drive links to the videos... hmm and yes I can take a couple pictures! How would I take this thread to the workbench section? Sorry I'm new here haha
  4. neikeel
    3,787
    2,200
    Pics and voltages and sound clips are all good:agreed:
    One or two things spring to mind:
    1) Failing preamp filter cap (on V2)
    2) Failing plate resistor
    3) Had similar thing with a JMP - turned out to be a corroded HT fuseholder internals caused intermittent connection with the amp being cranked sitting on the cab, weirdly a similar intermittent static sound that was not apparrent with all my other debugging tests................?
    mAx___ likes this.
  5. Frank Plante
    Dec 23, 2018
    18
    Here are a few pictures, tell me if you need more! Although I still can't post any link so I can't send you the soundclips
  6. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    762
    446
    I've had a problem similar to this that was caused by a cold solder joint. It can't hurt to check the connections with a magnifying glass.
  7. Frank Plante
    Dec 23, 2018
    18
    I already tried that, thanks though. Another thing to note is that I can play. the sound doesn't cut or anything like that. There's juste a weird static noise behind the sound of the amp, if that makes sense.
  8. ampmadscientist
    15,493
    9,382
    Have you measured the bias current with a meter?
    Do you have a bias probe?
    What output tubes are installed?
    Cold bias will cause static noise, almost like the sound of a blown speaker.
  9. Frank Plante
    Dec 23, 2018
    18
    I
    I was planning to order a bias probe in like 5 minutes haha, will the Eurotube one do the job?
  10. ampmadscientist
    15,493
    9,382
    Let's get more close up pictures of this area, output tube sockets.
    Looks like a burned screen resistor but can't see really clearly.
  11. anitoli
    anitoli Well-Known Member
    7,002
    8,015
    All you need to bias that amp is 4 1ohm 2w precision resistors placed across the cathode connection and a multimeter.
  12. ampmadscientist
    15,493
    9,382
    What meter do you have?
  13. Frank Plante
    Dec 23, 2018
    18
    Is that better?
    By the way, can I inbox you the links so that you can post them in the thread? I think a sound sample would be really good thing to have here haha
  14. Frank Plante
    Dec 23, 2018
    18
    My brother is an electronic tech, he has a bunch of multimeters
  15. ampmadscientist
    15,493
    9,382
    Looks like screen grid resistor is toast.
  16. Frank Plante
    Dec 23, 2018
    18
    Thanks! That would be the green one right? It is hard to see on the resistor itself, is there a way to know what the value of the resistor is?
  17. ampmadscientist
    15,493
    9,382
    Turn amp off
    Unplug power
    Remove the 2 output tubes.
    Set meter on ohms
    Measure between pin 4 and pin 6 of output tube socket(s).
    Both sockets should read 1000 ohms.
    If you don't get the 1000 ohms, the screen resistor should be replaced.
    1000 ohm, 5 watt, wire wound resistor.
    Usually these are replaced on both sockets so that the 2 resistors match.
  18. Frank Plante
    Dec 23, 2018
    18
    Thank you very much! I actually have 4 tubes, so I should replace the 4 resistors?
  19. ampmadscientist
    15,493
    9,382
    Take out all 4 tubes and test all 4 sockets.
    1000 ohms between pin 4 and pin 6 on each socket.
    But I think at least 1 is bad.
    Yes if you want you can make all 4 the same type.
    If you don't know how to solder find somebody to help you.
  20. ampmadscientist
    15,493
    9,382
    It's good your bro is a tech, he can help you replace the 4 sockets and the screen grid resistors.
    mAx___ likes this.
