Vintage Modern 2466 PPIMV for High Dynamic Range only
Discussion in 'The Workbench' started by George Marshall, Dec 15, 2019.
  1. mickeydg5
    23,547
    10,595
    By the way, how are all of the control knobs set?
    Inquiring minds like to know?
  2. sikter1969
    sikter1969 New Member
    Jun 22, 2009
    7
    There are two other ways to tame LDR and HDR volume difference on Vintage Modern without modding the amp.
    Boss LS2 pedal (or any clean boost pedal) can be connected in loop and wired so it switches simultaniously with LDR/HDR switch.
    Another better (more expensive) solution is to connect attenuator and wire it to be switching simultaniously with LDR/HDR switch.
    Actually there is yet another method I tested:
    Attaching microservo to Master Volume su it turns up the knob each time you switch back to LDR.
    All methods worked even though they are not perfect solutions but you do not need to be very technical to try them and no one require modification of VM.
