Vintage Inspired Jtm45/100 Block-end Build
Discussion in 'Building the Classics' started by valvestorm, Dec 23, 2016.
  1. valvestorm
    valvestorm New Member
    Nov 13, 2014
    11
    15
    Not a full blown museum piece, but a nod toward the vintage with some modern updates... the goal being to get the tone! Thanks to Neikeel for his help getting this right!
    Custom Back panel
    Block-end chassis begged from another builder
    Preamp section with switchable 100pf bright cap. Using some 110k plate caps to dial things in.
    Re-worked the power section to avoid switch pops and to accommodate Larry Grounding.
    NOS GECs
  2. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,009
    1,467
    Floating above Dallas in Marshall Heaven
    Beauty! Love KT66's. When do we get to hear it?
    Russ
  3. Michael RT
    Michael RT Well-Known Member VIP Member
    Jan 27, 2009
    10,513
    6,350
    Ontario, Canada
    Does it sound as good as it looks?? :cool:
    Metroman likes this.
  4. Ron W
    Ron W Active Member Sponsor
    Aug 7, 2014
    120
    29
    Coeur d' Alene, ID
    Great Scott, Robin! That looks magnificent. Clips please...
  5. neikeel
    2,731
    1,263
    Beautiful work, how do you find the bright cap switch works for you?
    Guess I am going to have to get my JH project out of the cupboard now! Been gathering the parts for 2 years now, I was not able to prise a block end chassis from George but I the Dickinson one is old style chassis.
  6. coldengray
    coldengray Active Member VIP Member
    May 19, 2011
    407
    184
    Great work Robert. Looks fantastic.
  7. v846
    v846 Member
    Mar 28, 2015
    39
    17
    Rockville , CT
    Beautiful build ! Love those GEC's , what are you running for ECC83's ?
  8. fusionbear
    fusionbear Member
    Oct 12, 2016
    58
    99
    Great Work Robert!!!
    What transformer brand and voltage is your PT?
  9. valvestorm
    Nov 13, 2014
    11
    15
    I like the bright cap at certain points on the volume rotation, but not others... also depends what pedals are in front. Glad I made it switchable.
    They are Harma retros
    Both transformers are the Metro versions made by Heyboer. The PT (1204-43) is running about 495v at the plates.
    https://store.metropoulos.net/collections/transformers
    ibmorjamn likes this.
  10. neikeel
    2,731
    1,263
    That is interesting how he now specs lower voltage on his PT now. I had one of the first batch he made up (before he went into production). I am pretty sure these were 530v on the plate with the UK taps.
    I would be interested to know what your PI and preamp valve plate voltages are. My 7206 replica has dual voltage options, one for the high and low voltage options, but I have been saving my last quad of NOS matched GECs for it, so I will be ok running the high voltage option if it sounds best.
  11. fusionbear
    fusionbear Member
    Oct 12, 2016
    58
    99
    Hello Robert, to piggyback on neikeel's comments, you may want to adjust the 82k resistor to a lower value between the choke and the PI in order to get the right voltages in the rest of the circuit. I suspect you may be as low as 178 B+ at the node that feeds V1. My build has the Metro/Heyboer PT and with 2-KT88's, I am at 510B+. I settled for 20k on mine.
  12. neikeel
    2,731
    1,263
    I think there is a typo above as the resistor between choke and PI is 8k2, I have seen vintage ones (well x2 PA 45/100s) with 4k7 5w resistors there, it may have been a popular mod or they came that way stock??
    Raising the PI voltage to design levels will give it more punch but that might be at the expense of V1 tuning (there are 110k plates on V1 and V2).
  13. fusionbear
    fusionbear Member
    Oct 12, 2016
    58
    99
    Aah, my bad, thank you for correcting me, it is a 8k2. The early schematic shows an 82k so I assumed:
    http://www.drtube.com/schematics/marshall/1959t-66.gif
    In that case, you may want to experiment with going up in value. I am happy with 12.9k on mine.
  14. fusionbear
    fusionbear Member
    Oct 12, 2016
    58
    99
    Here is a 67' PA version that I worked on with the 8k2 Iskra between the Choke and PI :
  15. coldengray
    May 19, 2011
    407
    184
    Carl - what is the board filter cap value on that '67? A friend of mine has a 67 PA head that has a HUGE modern cap on the board, I suggested he replace it with one of the 32/32 reformed Erie caps that Valvestorm sells. But I know the value is inconsistent, sometimes 16/16 and sometimes 20/20.
  16. Big Mike
    Big Mike Member
    Nov 15, 2007
    58
    21
    Raider Nation - SFO Bay Area
    lovin that. Beautiful work!!!
  17. coldengray
    May 19, 2011
    407
    184
    Glad to have you here, Big Mike!!
  18. Big Mike
    Big Mike Member
    Nov 15, 2007
    58
    21
    Gracias amigo. Been away too long. Nice to see a dedicated 'classics' forum. FUN stuff.
    coldengray likes this.
  19. neikeel
    2,731
    1,263
    Not Carl here but it is a single 16uF on there, typical for the 65 and 66 JTM45/100s running KT66s. Next in the line in early were typically 32/32 with 10k dropper between, slightly browner sound. Unusual to see the single cap with that cap board.
  20. fusionbear
    fusionbear Member
    Oct 12, 2016
    58
    99
    That is a single 16uf. Standard on this circuit
